Datasheet HMC903 (Analog Devices) - 3
Description6 GHz to 18 GHz GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page13 / 3 — Data Sheet. HMC903. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. …
RevisionC
File Format / SizePDF / 212 Kb
Data Sheet. HMC903. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
Data Sheet HMC903 SPECIFICATIONS ELECTRICAL SPECIFICATIONS Table 1 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
TA = 25°C, VDD1 = VDD2 = 3.5 V, IDQ = 90 mA. VGG1 = VGG2 = open for normal, self biased operation.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 6 18 GHz GAIN 17 19 dB Gain Variation over Temperature 0.013 dB/°C RETURN LOSS Input 11 dB Output 13 dB OUTPUT Output Power for 1 dB Compression P1dB 16 dBm Saturated Output Power PSAT 18 dBm Output Third-Order Intercept IP3 27 dBm NOISE FIGURE NF 1.6 2.1 dB SUPPLY CURRENT IDQ 90 mA VDD = 3.5 V, VGG1 = VGG2 = open Rev. C | Page 3 of 13 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding TYPICAL APPLICATION CIRCUITS ASSEMBLY DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE
