Datasheet HMC772LC4 (Analog Devices) - 3
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 2 - 12 GHz
Pages / Page6 / 3 — HMC772LC4. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 2 - 12 GHz. Output IP3 …
File Format / SizePDF / 388 Kb
HMC772LC4. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 2 - 12 GHz. Output IP3 vs. Temperature. Power Compression @ 12 GHz
HMC772LC4 GaAs HEMT MMIC LOW NOISE AMPLIFIER, 2 - 12 GHz Output IP3 vs Temperature Power Compression @ 12 GHz
HMC772LC4
v02.0514
GaAs HEMT MMIC LOW NOISE AMPLIFIER, 2 - 12 GHz Output IP3 vs. Temperature Power Compression @ 12 GHz
30 20 T 28 (%) M 15 PAE 26 ) Pout 10 Gain (dB), PAE (dBm 24 E - S IP3 GAIN 5 +25 C IS 22 +85 C - 40 C (dBm), O 0 20 Pout 18 -5 W N 1 3 5 7 9 11 13 15 -20 -15 -10 -5 0 5 FREQUENCY (GHz) INPUT POWER (dBm) O
Gain, Noise Figure & Power vs.
S - L
Reverse Isolation vs. Temperature Supply Voltage @ 12 GHz
R 0 24 8 IE Gain 7 -5 21 P1dB ) m 18 6 N LIF ) O -10 +25 C +85 C I (dB 5 S P (dB - 40 C 15 E N F IO -15 1dB 4 IG M T 12 U LA ), P R A O E (dB 9 3 IS -20 ( IN dB A 6 2 ) G -25 3 1 Noise Figure -30 0 0 1 3 5 7 9 11 13 15 3.5 4 4.5 FREQUENCY (GHz) Vdd (V) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
