Datasheet HMC772LC4 (Analog Devices) - 5
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 2 - 12 GHz
Pages / Page6 / 5 — HMC772LC4. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 2 - 12 GHz. Pin …
File Format / SizePDF / 388 Kb
HMC772LC4. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 2 - 12 GHz. Pin Descriptions. Application Circuit
HMC772LC4 GaAs HEMT MMIC LOW NOISE AMPLIFIER, 2 - 12 GHz Pin Descriptions Application Circuit
HMC772LC4
v02.0514
Pin Number Function Description Interface Schematic T 1, 2, 4 - 7, 12 - 15, These pins and ground paddle M GND 17 - 19, 24 must be connected to RF/DC ground. This pin is AC coupled 3 RFIN and matched to 50 Ohms. E - S Gate control for amplifier. Please follow “MMIC Amplifier IS 8 Vgg Biasing Procedure” application note. See application circuit O for required external components. Power Supply Voltage for the amplifier. See application circuit 9 Vdd W N for required external components. O The pins are not connected internally; however, all data 10, 11, 20 - 23 N/C shown herein was measured with these pins connected to RF/DC ground externally. S - L This pin is AC coupled R 16 RFOUT and matched to 50 Ohms. IE LIF P M A
Application Circuit
I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
