Datasheet HMC752LC4 (Analog Devices) - 6
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 24 - 28 GHz
Pages / Page7 / 6 — HMC752LC4. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 24 - 28 GHz. Pin …
HMC752LC4. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 24 - 28 GHz. Pin Descriptions. Application Circuit
HMC752LC4 GaAs HEMT MMIC LOW NOISE AMPLIFIER, 24 - 28 GHz Pin Descriptions Application Circuit
HMC752LC4
v02.0618
Pin Number Function Description Interface Schematic 1, 2, 4, 6, 7, 12, 13, Package bottom has exposed metal paddle GND T 15, 17 - 19, 24 that must be connected to RF/DC ground. M This pad is AC coupled 3 RFIN and matched to 50 Ohms. No Connection. This pin may be connected to RF/DC ground. 5, 11, 14, 22, 23 N/C Performance will not be affected. E - S IS Gate control for amplifier. Please follow “MMIC Amplifier Bias- O 8 - 10 Vgg1 - 3 ing Procedure” application note. See assembly for required external components. W N This pad is AC coupled 16 RFOUT O and matched to 50 Ohms. Power Supply Voltage for the amplifier. See assembly for 21, 20 Vdd1, Vdd2 required external components. S - L R IE
Application Circuit
LIF Component Value P C1 - C5 100 pF M C6 - C10 1,000 pF A C11 - C15 4.7 µF For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
6
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain, Noise Figure & P1dB vs. Supply Voltage @ 28 GHz Power Compression @ 28 GHz Reverse Isolation vs. Temperature Psat vs. Temperature P1dB vs. Temperature Output IP3 vs. Idd Output IP3 vs. Temperature Noise Figure vs. Idd Noise Figure vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Idd Gain vs. Temperature P1dB vs. Idd Absolute Maximum Ratings
