Datasheet HMC752LC4 (Analog Devices) - 7
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 24 - 28 GHz
Pages / Page7 / 7 — HMC752LC4. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 24 - 28 GHz. Evaluation …
HMC752LC4. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 24 - 28 GHz. Evaluation PCB. List of Materials for Evaluation PCB 123794 [1]
HMC752LC4 GaAs HEMT MMIC LOW NOISE AMPLIFIER, 24 - 28 GHz Evaluation PCB List of Materials for Evaluation PCB 123794 [1]
HMC752LC4
v02.0618
T M E - S IS O W N O S - L R IE LIF P M A
Item Description The circuit board used in this application should use J1, J2 2.92mm PCB mount K-Connector RF circuit design techniques. Signal lines should have 50 Ohm impedance while the package ground J3 - J9 DC Pin leads and exposed paddle should be connected C1 - C5 100pF Capacitor, 0402 Pkg. directly to the ground plane similar to that shown. C6 - C10 1,000pF Capacitor, 0603 Pkg. A sufficient number of via holes should be used to C11 - C15 4.7 µF Capacitor, Tantalum connect the top and bottom ground planes. The U1 HMC752LC4 Amplifier evaluation board should be mounted to an appro- PCB [2] 123792 Evaluation PCB [2] priate heat sink. The evaluation circuit board shown [1] Reference this number when ordering complete evaluation PCB is available from Analog Devices upon request. [2] Circuit Board Material: Rogers 4350 or Arlon 25FR For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
7
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain, Noise Figure & P1dB vs. Supply Voltage @ 28 GHz Power Compression @ 28 GHz Reverse Isolation vs. Temperature Psat vs. Temperature P1dB vs. Temperature Output IP3 vs. Idd Output IP3 vs. Temperature Noise Figure vs. Idd Noise Figure vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Idd Gain vs. Temperature P1dB vs. Idd Absolute Maximum Ratings
