Datasheet HMC751LC4 (Analog Devices) - 3
DescriptionSMT pHEMT LOW NOISE AMPLIFIER, 17 - 27 GHz
Pages / Page6 / 3 — HMC751LC4. SMT pHEMT LOW NOISE. AMpLIFIER, 17 - 27 GHz. p1dB vs. …
File Format / SizePDF / 355 Kb
HMC751LC4. SMT pHEMT LOW NOISE. AMpLIFIER, 17 - 27 GHz. p1dB vs. Temperature. p1dB vs. Supply Voltage. psat vs. Temperature
HMC751LC4 SMT pHEMT LOW NOISE AMpLIFIER, 17 - 27 GHz p1dB vs Temperature p1dB vs Supply Voltage psat vs Temperature
HMC751LC4
v01.0514
SMT pHEMT LOW NOISE AMpLIFIER, 17 - 27 GHz p1dB vs. Temperature p1dB vs. Supply Voltage
18 18 T 16 16 M 14 14 12 12 (dBm) (dB) E - S 10 10 GAIN P1dB IS 3.5 V 8 8 +25 C 4.0 V 4.5 V O +85 C 6 - 40 C 6 4 4 W N 14 16 18 20 22 24 26 28 30 14 16 18 20 22 24 26 28 30 FREQUENCY (GHz) FREQUENCY (GHz) O S - L
psat vs. Temperature Reverse Isolation vs. Temperature
R 18 0 IE 16 -10 +25 C 14 ) -20 LIF +85 C - 40 C P (dB 12 N -30 (dBm) IO M T 10 -40 LA A +25 C Psat O +85 C IS 8 - 40 C -50 6 -60 4 -70 14 16 18 20 22 24 26 28 30 14 16 18 20 22 24 26 28 30 FREQUENCY (GHz) FREQUENCY (GHz)
power Compression @ 21 GHz
30 (%) 25 PAE 20 (dB), 15 Pout Gain GAIN PAE 10 (dBm), 5 Pout 0 -25 -20 -15 -10 -5 INPUT POWER (dBm) I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
