Datasheet HMC751LC4 (Analog Devices) - 4
DescriptionSMT pHEMT LOW NOISE AMPLIFIER, 17 - 27 GHz
Pages / Page6 / 4 — HMC751LC4. SMT pHEMT LOW NOISE. AMpLIFIER, 17 - 27 GHz. Absolute Maximum …
File Format / SizePDF / 355 Kb
HMC751LC4. SMT pHEMT LOW NOISE. AMpLIFIER, 17 - 27 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd. Outline Drawing
HMC751LC4 SMT pHEMT LOW NOISE AMpLIFIER, 17 - 27 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd Outline Drawing
HMC751LC4
v01.0514
SMT pHEMT LOW NOISE AMpLIFIER, 17 - 27 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd1, Vdd2, Vdd3) +5.5 Vdc Vdd (Vdc) Idd (mA) RF Input Power (RFIN)(Vdd = +4 Vdc) -5 dBm +3.5 69 T Channel Temperature 175 °C +4.0 73 M Continuous Pdiss (T= 85 °C) 1 W +4.5 77 (derate 11.2 mW/°C above 85 °C) Thermal Resistance Note: Amplifier will operate over full voltage range shown 89 °C/W (channel to ground paddle) above. E - S Storage Temperature -65 to +150 °C IS Operating Temperature -40 to +85 °C ELECTROSTATIC SENSITIVE DEVICE O OBSERVE HANDLING PRECAUTIONS W N O
Outline Drawing
S - L R IE LIF P M A NOTES: 1. PACKAGE BODY MATERIAL: ALUMINA 2. LEAD AND GROUND PADDLE PLATING: 30-80 MICROINCHES GOLD OVER 50 MICROINCHES MINIMUM NICKEL 3. DIMENSIONS ARE IN INCHES [MILLIMETERS] 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm DATUM 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND
package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC751LC4 Alumina, White Gold over Nickel MSL3 [1] H751 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
4
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
