Datasheet ADL5523 (Analog Devices) - 8
Description400 MHz to 4000 MHz Low Noise Amplifier
Pages / Page21 / 8 — ADL5523. Data Sheet. 1950 MHZ, VPOS = 5 V. 2.0. S21. 1.8. 1.6. ) B. 1.4. …
RevisionC
File Format / SizePDF / 685 Kb
ADL5523. Data Sheet. 1950 MHZ, VPOS = 5 V. 2.0. S21. 1.8. 1.6. ) B. 1.4. S (d. S11. E (dB. 1.2. –10. 1.0. MET A. –15. E FIGU. 0.8. –20. S12. OIS. S-PA. 0.6. –25. 0.4. –30
ADL5523 Data Sheet 1950 MHZ, VPOS = 5 V 2.0 S21 1.8 1.6 ) B 1.4 S (d S11 E (dB 1.2 –10 1.0 MET A –15 E FIGU 0.8 –20 S12 OIS S-PA 0.6 –25 0.4 –30
Matched for optimal noise figure, external matching circuit included.
20 2.0 15 S21 1.8 10 1.6 5 ) B ) 1.4 0 S (d –5 S11 E (dB 1.2 ER R –10 1.0 MET A –15 R E FIGU 0.8 –20 S12 OIS S-PA N 0.6 –25 0.4 –30 S22 –35 0.2 –40 0 1800 1850 1900 1950 2000 2050 2100 2150 2200
009
1800 1820 1840 1860 1880 1900 1920 1940 1960 1980 2000
012
FREQUENCY (MHz)
06829-
FREQUENCY (MHz)
06829- Figure 9. Typical S-Parameters, Log Magnitude Figure 12. Noise Figure vs. Frequency at 25°C, Multiple Devices
18 45 20.5 40 –40°C OIP3 16 GAIN 40 20.0 38 19.5 36 14 OIP3 35 +25°C dB) 19.0 34 N ( 12 30 AI 18.5 32 dBm) dBm) +85°C 10 25 B ( 18.0 30 B ( dB) AND G 1d 1d P1dB 17.5 –40°C 28 N ( 8 20 URE AI +25°C G 17.0 26 IG 6 15 +85°C IP3 AND P 16.5 24 IP3 AND P –40°C ISE F O GAIN P1dB O 4 10 16.0 22 NO 15.5 +25°C 20 2 5 NOISE FIGURE 15.0 18 +85°C 0 0 14.5 16 1920 1930 1940 1950 1960 1970 1980
010
013
FREQUENCY (MHz)
06829-
FREQUENCY (MHz)
06829- Figure 10. Noise Figure, Gain, OIP3, and P1dB vs. Frequency Figure 13. Gain, OIP3, and P1dB vs. Temperature
2.0 42 1.8 40 –40°C 38 1.6 36 ) 1.4 +85°C +25°C 34 E (dB 1.2 R 32 +25°C 1.0 dBm) 30 +85°C E FIGU IP3 ( 0.8 28 O OIS –40°C N 26 0.6 24 0.4 22 0.2 20 0 18 1800 1820 1840 1860 1880 1900 1920 1940 1960 1980 2000
011
–8 –6 –4 –2 0 2 4 6 8 10 12 14 16 18 20 22
014
FREQUENCY (MHz) P
06829-
OUT PER TONE (dBm)
06829- Figure 11. Noise Figure vs. Temperature Figure 14. OIP3 vs. Output Power (POUT) and Temperature Rev. C | Page 8 of 21 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DC SPECIFICATIONS DE-EMBEDDED S-PARAMETERS, VPOS = 3 V TO 5 V, RFIN = PORT 1, VPOS = PORT 2, RFOUT = PORT 3 ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 900 MHz, VPOS = 5 V 1950 MHZ, VPOS = 5 V 2600 MHz, VPOS = 5 V 3500 MHz, VPOS = 5 V 900 MHz, VPOS = 3 V 1950 MHz, VPOS = 3 V 2600 MHz, VPOS = 3 V 3500 MHz, VPOS = 3 V DC CHARACTERISTICS BASIC CONNECTIONS EVALUATION BOARD SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN TUNING THE ADL5523 FOR OPTIMAL NOISE FIGURE TUNING S22 TUNING THE LNA INPUT FOR OPTIMAL GAIN TUNING THE LNA INPUT FOR OPTIMAL NOISE FIGURE S11 OF THE LNA WITH S22 MATCHED OUTLINE DIMENSIONS ORDERING GUIDE
