Datasheet HMC639ST89, 639ST89E (Analog Devices) - 2
DescriptionHigh IP3, Low Noise Amplifier, 0.2 - 4.0 GHz
Pages / Page6 / 2 — HMC639ST89 / 639ST89E. HIGH IP3, LOW NOISE. AMPLIFIER, 0.2 - 4.0 GHz. …
File Format / SizePDF / 354 Kb
HMC639ST89 / 639ST89E. HIGH IP3, LOW NOISE. AMPLIFIER, 0.2 - 4.0 GHz. Broadband Gain & Return Loss. Gain vs. Temperature
HMC639ST89 / 639ST89E HIGH IP3, LOW NOISE AMPLIFIER, 0.2 - 4.0 GHz Broadband Gain & Return Loss Gain vs Temperature
v03.0810
HIGH IP3, LOW NOISE AMPLIFIER, 0.2 - 4.0 GHz Broadband Gain & Return Loss Gain vs. Temperature
20 16 15 14 10 12 ) (dB 5 ) 10 S21 E S S11 N (dB 0 S22 8 O IN P A S -5 G E 6 R +25C +85C -10 4 -40C 9 -15 2 -20 0 T 0 1 2 3 4 5 6 0 1 2 3 4 5 FREQUENCY (GHz) FREQUENCY (GHz) M R - S
Input Return Loss vs. Temperature Output Return Loss vs. Temperature
E 0 0 W +25C +25C O ) -5 +85C ) -5 +85C -40C -40C (dB (dB S S S S LO -10 LO -10 N N R R R & P U U T T E E A R R -15 -15 E IN -20 -20 0 1 2 3 4 5 0 1 2 3 4 5 FREQUENCY (GHz) FREQUENCY (GHz) S - L R IE
Reverse Isolation vs. Temperature Noise Figure vs. Temperature
0 10 LIF ) P -5 8 (dB ) M N IO +25C (dB T E +25C A -10 +85C 6 R +85C LA -40C U O -40C IG IS F E -15 E S 4 R IS E O V N E R -20 2 -25 0 0 1 2 3 4 5 0 1 2 3 4 5 FREQUENCY (GHz) FREQUENCY (GHz) Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
9 - 2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
