HMC639ST89 / 639ST89E v03.0810 HIGH IP3, LOW NOISEAMPLIFIER, 0.2 - 4.0 GHzP1dB vs. TemperaturePsat vs. Temperature 30 30 25 25 20 20 (dBm) +25C (dBm) 15 15 +85C 9 -40C P1dB Psat +25C 10 +85C 10 -40C 5 5 T 0 0 M 0 1 2 3 4 0 1 2 3 4 FREQUENCY (GHz) FREQUENCY (GHz) R - S E Power Compression @ 850 MHzPower Compression @ 2200 MHz W 32 32 O ) Pout Pout (% (% 24 E Gain 24 E Gain A PAE A PAE ), P ), P 16 16 (dB (dB R & P IN IN A A A ), G 8 ), G 8 E m m IN 0 0 out (dB out (dB P P -8 -8 -20 -12 -4 4 12 20 -20 -12 -4 4 12 20 S - L INPUT POWER (dBm) INPUT POWER (dBm) R IE Gain, Power, Output IP3 & Supply CurrentOutput IP3 vs. Output Tone Powervs. Supply Voltage @ 850 MHz LIF P 45 160 160 M (dBm) 140 Gain 140 40 P1dB A IP3 Psat 120 IP3 120 ) 35 (dBm), 100 100 I (dBm s 80 80 (m 0 dBm Is IP3 ), Psat A 30 5 dBm m ) 10 dBm 60 60 (dB 25 40 40 1dB ), P 20 20 20 (dB IN 0 0 0 1 2 3 4 A G 4.5 4.75 5 5.25 5.5 FREQUENCY (GHz) Vs (V) Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m 9 - 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
