Datasheet HMC-AUH232 (Analog Devices) - 4
DescriptionGaAs HEMT MMIC MODULATOR DRIVER AMPLIFIER, DC - 43 GHz
Pages / Page10 / 4 — HMC-AUH232. GaAs HEMT MMIC MODULATOR. DRIVER AMPLIFIER, DC - 43 GHz. …
File Format / SizePDF / 565 Kb
HMC-AUH232. GaAs HEMT MMIC MODULATOR. DRIVER AMPLIFIER, DC - 43 GHz. Absolute Maximum Ratings. Input Reference Signal
HMC-AUH232 GaAs HEMT MMIC MODULATOR DRIVER AMPLIFIER, DC - 43 GHz Absolute Maximum Ratings Input Reference Signal
HMC-AUH232
v02.0209
Drain Bias Voltage (Vdd) +6 Vdc Gain Bias Voltage (Vgg1) -1.5 to 0 Vdc ELECTROSTATIC SENSITIVE DEVICE Output Voltage Adjust (Vgg2) 0 to +2 Vdc OBSERVE HANDLING PRECAUTIONS RF Input Power +18.5 dBm 40 Gb/s Input Voltage Pk-Pk (Vpp) 3V Thermal Resistance 48 °C/W (channel to die bottom) 4 Channel Temperature 180 °C Storage Temperature -65 to +150 °C Operating Temperature -55 to +110 °C IP H
S - C PRBS=231-1, 2.1V Input, Data rate of 40 Gb/s R IE IF L P M R A E IV R L D
Output Reference Signal
A PRBS=231-1, 7.3V Input, Data rate of 40 Gb/s IC T P E & O V A W O R IC M Note: Measured Performance Characteristics (Typical Performance at 25°C) (Measured data obtained from die in a test fi xture unless otherwise stated) Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
4 - 5
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
