Datasheet HMC-ALH435 (Analog Devices)
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 5 - 20 GHz
Pages / Page6 / 1 — HMC-ALH435. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 5 - 20 GHz. Typical …
File Format / SizePDF / 296 Kb
HMC-ALH435. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 5 - 20 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC-ALH435 Analog Devices
HMC-ALH435
v03.1009
1
Typical Applications Features
This HMC-ALH435 is ideal for: IP Noise Figure: 2.2 dB @ 12 GHz H • Wideband Communication Systems Gain: 13 dB @ 14 GHz • Surveillance Systems C P1dB Output Power: +16 dBm @ 12 GHz - • Point-to-Point Radios Supply Voltage: +5V @ 30 mA • Point-to-Multi-Point Radios RS Die Size: 1.48 x 0.9 x 0.1 mm • Military & Space IE • Test Instrumentation IF L • VSAT P M
A E The HMC-ALH435 is a GaAs MMIC HEMT Low Noise IS Wideband Amplifi er die which operates between 5 O and 20 GHz. The amplifi er provides 13 dB of gain, 2.2 dB noise fi gure at 12 GHz and +16 dBm of output N power at 1 dB gain compression while requiring only W 30 mA from a +5V supply voltage. The HMC-ALH435 O amplifi er is ideal for integration into Multi-Chip- L Modules (MCMs) due to its small size.
Electrical Specifi cations, T = +25° C, Vdd= +5V A
Parameter Min. Typ. Max. Units Frequency Range 5 - 20 GHz Gain 10 13 dB Gain Variation over Temperature 0.02 dB / °C Noise Figure 2.2 2.6 dB Input Return Loss 5 dB Output Return Loss 10 dB Output IP3 25 dBm Output Power for 1 dB Compression 16 dBm Supply Current (Idd) 30 mA (Vdd = 5V, Vgg1 = -0.5V Typ., Vgg2 = 1.5V Typ) *Unless otherwise indicated, all measurements are from probed die Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 180
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
