Datasheet HMC-ALH102 (Analog Devices)
DescriptionGaAs HEMT MMIC WIDEBAND LOW NOISE AMPLIFIER, 2 - 20 GHz
Pages / Page6 / 1 — HMC-ALH102. GaAs HEMT MMIC WIDEBAND. LOW NOISE AMPLIFIER, 2 - 20 GHz. …
File Format / SizePDF / 464 Kb
HMC-ALH102. GaAs HEMT MMIC WIDEBAND. LOW NOISE AMPLIFIER, 2 - 20 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC-ALH102 Analog Devices
HMC-ALH102
v03.0118
GaAs HEMT MMIC WIDEBAND LOW NOISE AMPLIFIER, 2 - 20 GHz Typical Applications Features
This HMC-ALH102 is ideal for: Noise Figure: 2.5 dB IP • Wideband Communications Receivers Gain: 11.6 dB @ 10 GHz H • Surveil ance Systems P1dB Output Power: +10 dBm C • Point-to-Point Radios Supply Voltage: +2V @ 55 mA - • Point-to-Multi-Point Radios Die Size: 3.0 x 1.435 x 0.1 mm S R • Military & Space IE • Test Instrumentation LIF P
M The HMC-ALH102 is a GaAs MMIC HEMT Low Noise A Distributed Amplifier die which operates between E 2 and 20 GHz. The amplifier provides 11.6 dB of gain IS at 10 GHz, 2.5 dB noise figure and +10 dBm of out- O put power at 1 dB gain compression while requiring only 55 mA from a +2V supply voltage. The HMC- N ALH102 amplifier is ideal for integration into Multi- W Chip-Modules (MCMs) due to its small size. LO
Electrical Specifications, T = +25° C, Vdd= 2V [1], Idd = 55mA [2] A
Parameter Min. Typ. Max. Units Frequency Range 2 - 20 GHz Gain 8 10 dB Input Return Loss 15 dB Output Return Loss 12 dB Output Power for 1 dB Compression 8 10 dBm Noise Figure 2.5 dB Supply Current (Idd) 55 mA [1] Unless otherwise indicated, all measurements are from probed die [2] Adjust Vgg between -1V to +0.3V (Typ. -0.5V) to achieve Idd= 55 mA Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
