Datasheet HMC566LP4E (Analog Devices) - 5
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 28 - 36 GHz
Pages / Page6 / 5 — HMC566LP4E. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 28 - 36 GHz. Outline …
File Format / SizePDF / 417 Kb
HMC566LP4E. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 28 - 36 GHz. Outline Drawing. Package Information. 7 - 5
HMC566LP4E GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 28 - 36 GHz Outline Drawing Package Information 7 - 5
HMC566LP4E
v02.0609
7
Outline Drawing
T m s e - is o w N lo s - r ie lif p m A NoTes: 1. leADfrAme mATeriAl: Copper AlloY 2. DimeNsioNs Are iN iNCHes [millimeTers] 3. leAD spACiNG TolerANCe is NoN-CUmUlATiVe 4. pAD BUrr leNGTH sHAll Be 0.15mm mAXimUm. pAD BUrr HeiGHT sHAll Be 0.05mm mAXimUm. 5. pACKAGe wArp sHAll NoT eXCeeD 0.05mm. 6. All GroUND leADs AND GroUND pADDle mUsT Be solDereD To pCB rf GroUND. 7. refer To HiTTiTe AppliCATioN NoTe for sUGGesTeD lAND pATTerN.
Package Information
part Number package Body material lead finish package marking [1] HmC566lp4e roHs-compliant low stress injection molded plastic 100% matte sn [2] H566 XXXX [1] 4-Digit lot number XXXX [2] max peak reflow temperature of 260 °C Info F rmoatri op n rfiurcne is ,h ed d ebly ivAe n r al y o g aDn evdic eto s i p s bla eli c evee d otro dbe e ras: cc uH ratite tiatne d M reli iac bl reo . w Ho av wev e er , Cno o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No O P r h d o e ne r O : 7 n 81- -3li 2n 9 e - 4 a 7 t 0 ww 0 • O w rd .h e it r o tniltie n .c e ao t m
7 - 5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p li coarti o ap n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
