Datasheet HMC460LC5 (Analog Devices)
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, DC - 20 GHz
Pages / Page7 / 1 — HMC460LC5. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, DC - 20 GHz. Typical …
HMC460LC5. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, DC - 20 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC460LC5 Analog Devices
HMC460LC5
v08.1217
GaAs pHEMT MMIC LOW NOISE AMPLIFIER, DC - 20 GHz Typical Applications Features
The HMC460LC5 is ideal for: Noise Figure: 2.5 dB @ 10 GHz T • Telecom Infrastructure Gain: 14 dB @ 10 GHz M • Microwave Radio & VSAT P1dB Output Power: +16.5 dBm @ 10 GHz • Military & Space Supply Voltage: +8V @ 75 mA E - S • Test Instrumentation 50 Ohm Matched Input/Output IS 32 Lead Ceramic 5 x 5 mm SMT Package: 25 mm2 O
W N The HMC460LC5 is a GaAs MMIC pHEMT Low Noise O Distributed Amplifier in a leadless 5 x 5 mm ceramic surface mount package which operates from DC to 20 GHz. The amplifier provides 14 dB of gain, 2.5 dB S - L noise figure and +16.5 dBm of output power at 1 dB R gain compression while requiring only 75 mA from a IE Vdd = 8V supply. Gain flatness is excel ent from DC to 20 GHz making the HMC460LC5 ideal for EW, LIF ECM, Radar and test equipment applications. The P wideband amplifier I/Os are internal y matched to M 50 Ohms. A
Electrical Specifications, T = +25 °C, Vdd= 8V, Idd= 75 mA* A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range DC - 6.0 6.0 - 18.0 18.0 - 20.0 GHz Gain 11 14 11 14 10 13 dB Gain Flatness ± 0.5 ± 0.15 ± 0.25 dB Gain Variation Over Temperature 0.008 0.01 0.01 dB/ °C Noise Figure 3.5 5.0 2.5 4.0 3.5 5 dB Input Return Loss 17 18 12 dB Output Return Loss 17 15 15 dB Output Power for 1 dB Compression (P1dB) 14 17 13 16 12 15 dBm Saturated Output Power (Psat) 18 18 17 dBm Output Third Order Intercept (IP3) 29.5 29 28.5 dBm Supply Current 75 75 75 mA (Idd) (Vdd= 8V, Vgg= -0.9V Typ.) *Adjust Vgg between -2 to 0V to achieve Idd= 75 mA typical. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Broadband Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Temperature P1dB vs. Temperature Psat vs. Temperature Output IP3 vs. Temperature Gain, Power & Noise Figure vs. Supply Voltage @ 10 GHz, Fixed Vgg Reverse Isolation vs. Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing
