Datasheet HMC460LC5 (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, DC - 20 GHz
Pages / Page7 / 4 — HMC460LC5. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, DC - 20 GHz. Absolute …
HMC460LC5. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, DC - 20 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC460LC5 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, DC - 20 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC460LC5
v08.1217
GaAs pHEMT MMIC LOW NOISE AMPLIFIER, DC - 20 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) +9 Vdc Gate Bias Voltage (Vgg) -2 to 0 Vdc Vdd (V) Idd (mA) T Gate Bias Voltage (Igg) 2.5 mA +7.5 74 M RF Input Power (RFIN)(Vdd = +8 Vdc) +18 dBm +8.0 75 Channel Temperature 175 °C +8.5 76 Continuous Pdiss (T = 85 °C) E - S 2 W (derate 23 mW/°C above 85 °C) IS Thermal Resistance 44.4 °C/W (channel to package bottom) ELECTROSTATIC SENSITIVE DEVICE O Storage Temperature -65 to +150 °C OBSERVE HANDLING PRECAUTIONS Operating Temperature -55 to +85 °C
32-Terminal Ceramic Leadless Chip Carrier [LCC]
W N ESD Sensitivity (HBM) Class 1A
(E-32-1) Dimensions shown in millimeters.
O
Outline Drawing
S - L
5.05 0.36 4.90 SQ
R
0.30 PIN 1 4.75 INDICATOR 0.08 0.24
IE
REF 25 32 PIN 1 24 1
LIF
0.50 BSC 3.60
P
EXPOSED PAD 3.50 SQ
M
3.40
A
17 8 16 9 0.38 TOP VIEW BOTTOM VIEW 0.20 MIN 0.32 3.50 REF 0.26 1.10 4.10 REF 1.00 SIDE VIEW 0.90 FOR PROPER CONNECTION OF THE EXPOSED PAD, REFER TO THE PIN CONFIGURATION AND SEATING FUNCTION DESCRIPTIONS PLANE SECTION OF THIS DATA SHEET. PKG-004843 04-24-2017-D
32-Terminal Ceramic Leadless Chip Carrier [LCC] (E-32-1) Dimensions shown in mil imeters.
ORDERING GUIDE
Part Number Package Material Lead Finish MSL Rating Package Marking [2] H460 HMC460LC5 Alumina, White Gold over Nickel MSL3 [1] XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
4
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Broadband Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Temperature P1dB vs. Temperature Psat vs. Temperature Output IP3 vs. Temperature Gain, Power & Noise Figure vs. Supply Voltage @ 10 GHz, Fixed Vgg Reverse Isolation vs. Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing
