Datasheet HMC490LP5, 490LP5E (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz
Pages / Page8 / 4 — HMC490LP5 / 490LP5E. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - …
File Format / SizePDF / 419 Kb
HMC490LP5 / 490LP5E. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - 16 GHz. Reverse Isolation vs. Temperature
HMC490LP5 / 490LP5E GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz Reverse Isolation vs Temperature
HMC490LP5 / 490LP5E
v04.0213
GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz Reverse Isolation vs. Temperature
0 -10 T ) -20 (dB M N -30 IO T LA -40 O IS -50 R - S -60 IE -70 10 11 12 13 14 15 16 17 18 LIF FREQUENCY (GHz) P +25 C +85 C -40 C M E A IS O W N LO
Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd1, Vdd2, Vdd3) +5.5V Vdd (V) Idd (mA) Gate Bias Voltage (Vgg) -4 to 0V +3.0 140 RF Input Power (RFIN)(Vdd = +5V) +10 dBm +3.5 154 Channel Temperature 175 °C +4.0 168 Continuous Pdiss (T = 85 °C) 1.6 W (derate 17.9 mW/°C above 85 °C) +4.5 188 Thermal Resistance +5.0 200 56 °C/W (channel to ground paddle) +5.5 208 Storage Temperature -65 to +150 °C Operating Temperature -40 to +85 °C Note: Amplifier will operate over full voltage ranges shown above. ELECTROSTATIC SENSITIVE DEVICE OBSERVE HANDLING PRECAUTIONS Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
