Datasheet HMC490 (Analog Devices) - 6
DescriptionGaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 17 GHz
Pages / Page8 / 6 — HMC490. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - 17 GHz. Pad …
File Format / SizePDF / 411 Kb
HMC490. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - 17 GHz. Pad Descriptions. Assembly Diagram
HMC490 GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 17 GHz Pad Descriptions Assembly Diagram
HMC490
v03.0213
Pad Number Function Description Interface Schematic IP Gate control for amplifier. Adjust to achieve Id of 200 mA. Please follow “MMIC Amplifier Biasing Procedure” H 1,8, 7 Vgg1, 2, 3 Application Note. External bypass capacitors of 100 pF and 0.01 µF are required. C - R This pad is AC coupled 2 RFIN and matched to 50 Ohms. IE LIF Power Supply Voltage for the amplifier. External bypass capacitors 3, 4, 5 Vdd1, 2, 3 of 100 pF and 0.01 µF are required. P M A This pad is AC coupled 6 RFOUT and matched to 50 Ohms. E IS Die Bottom GND Die Bottom must be connected to RF/DC ground. O N
Assembly Diagram
W LO Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
