Datasheet HMC462 (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz
Pages / Page8 / 4 — HMC462. GaAs pHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. Power …
File Format / SizePDF / 448 Kb
HMC462. GaAs pHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. Power Compression @ 4 GHz. Power Compression @ 12 GHz
HMC462 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz Power Compression @ 4 GHz Power Compression @ 12 GHz
HMC462
v02.0213
20 20 (%) (%) 16 16 PAE PAE ip 12 (dB), 12 (dB), h GAIN GAIN C 8 8 - (dBm), (dBm), 4 4 s Pout Pout r 0 0 -15 -13 -11 -9 -7 -5 -3 -1 1 3 5 7 -15 -13 -11 -9 -7 -5 -3 -1 1 3 5 7 ie INPUT POWER (dBm) INPUT POWER (dBm) Pout Gain PAE Pout Gain PAE lif p m A
Power Compression @ 20 GHz Power Dissipation
e 20 0.6 is (%) 0.5 16 (W) o PAE 0.4 12 (dB), N 0.3 GAIN DISSIPATION w 8 0.2 (dBm), 4 POWER 0.1 lo Pout - 0 0 s -14 -12 -10 -8 -6 -4 -2 0 2 4 -14 -12 -10 -8 -6 -4 -2 0 2 4 6 8 INPUT POWER (dBm) INPUT POWER (dBm) r Pout Gain PAE 4 GHz 12 GHz 20 GHz ie lif p m A Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
