Datasheet HMC462 (Analog Devices) - 7
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz
Pages / Page8 / 7 — HMC462. GaAs pHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. Mounting & …
File Format / SizePDF / 448 Kb
HMC462. GaAs pHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. Mounting & Bonding Techniques for Millimeterwave GaAs MMICs
HMC462 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz Mounting & Bonding Techniques for Millimeterwave GaAs MMICs
HMC462
v02.0213
ip The die should be attached directly to the ground plane eutectical y or with conductive epoxy (see hmC general han- h dling, mounting, Bonding Note). 50 ohm microstrip transmission lines on 0.127mm (5 mil) thick alumina thin film substrates are recommended for C bringing rf to and from the chip (figure 1). if 0.254mm (10 mil) thick alumina thin film substrates must be used, the - die should be raised 0.150mm (6 mils) so that the surface of the die is coplanar with the surface of the substrate. one s way to accomplish this is to attach the 0.102mm (4 mil) thick die to a 0.150mm (6 mil) thick molybdenum heat spreader r (moly-tab) which is then attached to the ground plane (figure 2). ie microstrip substrates should be located as close to the die as possible in order to minimize bond wire length. Typical die-to-substrate spacing is 0.076mm to 0.152 mm (3 to 6 mils). lif 0.102mm (0.004”) Thick GaAs MMIC p
Handling Precautions
Wire Bond m Follow these precautions to avoid permanent damage. 0.076mm
Storage:
All bare die are placed in either waffle or Gel based esD protec- A (0.003”) tive containers, and then sealed in an esD protective bag for shipment. e once the sealed esD protective bag has been opened, all die should be is stored in a dry nitrogen environment. RF Ground Plane o
Cleanliness:
handle the chips in a clean environment. Do NoT attempt to clean the chip using liquid cleaning systems. N
Static Sensitivity:
fol ow esD precautions to protect against > ± 250V w esD strikes. 0.127mm (0.005”) Thick Alumina Thin Film Substrate
Transients:
suppress instrument and bias supply transients while bias is Figure 1. lo applied. Use shielded signal and bias cables to minimize inductive pick- - up. 0.102mm (0.004”) Thick GaAs MMIC s
General Handling:
handle the chip along the edges with a vacuum col et Wire Bond r or with a sharp pair of bent tweezers. The surface of the chip may have 0.076mm (0.003”) ie fragile air bridges and should not be touched with vacuum col et, twee- zers, or fingers. lif
Mounting
p The chip is back-metal ized and can be die mounted with Ausn eutec- RF Ground Plane m tic preforms or with electrical y conductive epoxy. The mounting surface 0.150mm (0.005”) Thick A should be clean and flat. Moly Tab eutectic Die Attach: A 80/20 gold tin preform is recommended with a work 0.254mm (0.010”) Thick Alumina Thin Film Substrate surface temperature of 255 °C and a tool temperature of 265 °C. when Figure 2. hot 90/10 nitrogen/hydrogen gas is applied, tool tip temperature should be 290 °C. Do NoT expose the chip to a temperature greater than 320 °C for more than 20 seconds. No more than 3 seconds of scrubbing should be required for attachment. epoxy Die Attach: Apply a minimum amount of epoxy to the mounting surface so that a thin epoxy fil et is observed around the perimeter of the chip once it is placed into position. Cure epoxy per the manufacturer’s schedule.
Wire Bonding
Ball or wedge bond with 0.025mm (1 mil) diameter pure gold wire. Thermosonic wirebonding with a nominal stage temperature of 150 °C and a ball bonding force of 40 to 50 grams or wedge bonding force of 18 to 22 grams is recom- mended. Use the minimum level of ultrasonic energy to achieve reliable wirebonds. wirebonds should be started on the chip and terminated on the package or substrate. All bonds should be as short as possible <0.31mm (12 mils). Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
