Datasheet HMC372LP3, 372LP3E (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz
Pages / Page8 / 3 — HMC372LP3 / 372LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 …
File Format / SizePDF / 397 Kb
HMC372LP3 / 372LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 MHz. Input Return Loss vs. Temperature
HMC372LP3 / 372LP3E GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz Input Return Loss vs Temperature
HMC372LP3 / 372LP3E
v03.0610
7
Input Return Loss vs. Temperature Output Return Loss vs. Temperature
0 0 T -2 -5 -4 -10 + 25 C -6 + 85 C +25 C - 40 C +85 C -15 -8 -40 C E - SM -20 -10 -12 IS -25 -14 RETURN LOSS (dB) RETURN LOSS (dB) -30 -16 -35 -18 -40 -20 W NO 0.7 0.75 0.8 0.85 0.9 0.95 1 0.7 0.75 0.8 0.85 0.9 0.95 1 O FREQUENCY (GHz) FREQUENCY (GHz) - L S
Output IP3 vs. Temperature P1dB & Psat vs. Temperature
R 40 25 IE 39 24 IF 38 + 25 C 23 L + 85 C PSAT 37 - 40 C 22 P 36 21 M 35 20 P1dB A 34 19 33 18 +25 C OUTPUT IP3 (dBm) +85 C 32 17 COMPRESSION POINT (dBm) -40 C 31 16 30 15 0.7 0.75 0.8 0.85 0.9 0.95 1 0.7 0.75 0.8 0.85 0.9 0.95 1 FREQUENCY (GHz) FREQUENCY (GHz)
Output IP3 vs. Vdd P1dB vs. Vdd
40 25 39 24 38 + 4.5 V 23 + 5.0 V 37 + 5.5 V 22 36 21 35 20 34 19 P1dB (dBm) 33 18 + 4.5 V OUTPUT IP3 (dBm) + 5.0 V 32 17 + 5.5 V 31 16 30 15 0.7 0.75 0.8 0.85 0.9 0.95 1 0.7 0.75 0.8 0.85 0.9 0.95 1 FREQUENCY (GHz) FREQUENCY (GHz) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
7 - 54
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
