Datasheet HMC372LP3, 372LP3E (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz
Pages / Page8 / 4 — HMC372LP3 / 372LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 …
File Format / SizePDF / 397 Kb
HMC372LP3 / 372LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 MHz. Output IP3 vs. Input Power @ 950 MHz
HMC372LP3 / 372LP3E GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz Output IP3 vs Input Power @ 950 MHz
HMC372LP3 / 372LP3E
v03.0610
7
Output IP3 vs. Input Power @ 950 MHz Reverse Isolation vs. Temperature
40 0 39 T 1 MHz Tone Separation -5 38 6 MHz Tone Separation 37 +25 C -10 +85 C -40 C 36 35 -15 E - SM 34 ISOLATION (dB) -20 33 OUTPUT IP3 (dBm) IS 32 -25 31 30 -30 -20 -15 -10 -5 0 0.7 0.75 0.8 0.85 0.9 0.95 1 W NO INPUT POWER PER TONE (dBM) FREQUENCY (GHz) O - L
Absolute Maximum Ratings Typical Supply Current vs. Vdd
S Drain Bias Voltage (Vdd) +8.0 Vdc Vdd (Vdc) Idd (mA) R RF Input Power (RFIN)(Vs = +5.0 Vdc) +15 dBm +4.5 98 IE Channel Temperature 150 °C +5.0 100 IF Continuous Pdiss (T = 85 °C) +5.5 102 L 1.015 W (derate 15.6 mW/°C above 85 °C) P Thermal Resistance 64.1 °C/W M (channel to ground paddle) A Storage Temperature -65 to +150 °C ELECTROSTATIC SENSITIVE DEVICE Operating Temperature -40 to +85 °C OBSERVE HANDLING PRECAUTIONS Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
7 - 55
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
