Datasheet ADPA7006CHIP (Analog Devices) - 8
Description18 GHz to 44 GHz, GaAs, pHEMT, MMIC, 1/2 W Power Amplifier
Pages / Page24 / 8 — ADPA7006CHIP. Data Sheet. +85°C. 700mA. +25°C. 800mA. –55°C. 900mA. –10. …
File Format / SizePDF / 465 Kb
ADPA7006CHIP. Data Sheet. +85°C. 700mA. +25°C. 800mA. –55°C. 900mA. –10. URN L. URN. –15. P IN. UT O. –20. –25. FREQUENCY (GHz). (d S. S S. URN L T. UT P. –30
ADPA7006CHIP Data Sheet +85°C 700mA +25°C 800mA –55°C 900mA –10 URN L URN –15 P IN UT O –20 –25 FREQUENCY (GHz) (d S S S URN L T UT P –30
ADPA7006CHIP Data Sheet 0 0 +85°C 700mA –5 +25°C 800mA –5 B) –55°C B) 900mA (d (d S S S S O O –10 –10 L URN L URN T T –15 RE –15 RE UT UT P P IN UT O –20 –20 –25 –25 18 20 22 24 26 28 30 32 34 36 38 40 42 44
-016
-019
FREQUENCY (GHz)
186
FREQUENCY (GHz)
186 20 20 Figure 16. Input Return Loss vs. Frequency for Various IDQ Values, VDD = 5 V Figure 19. Output Return Loss vs. Frequency for Various Temperatures, VDD = 5 V, IDQ = 800 mA
0 0 5V –5 4V 700mA –5 B) B) 800mA 900mA (d S (d –10 S S S O O –10 URN L –15 T URN L T RE RE –15 UT –20 P UT P UT UT O O –20 –25 –30 –25 18 20 22 24 26 28 30 32 34 36 38 40 42 44
-017
-020
FREQUENCY (GHz)
186 186 20
FREQUENCY (GHz)
20 Figure 17. Output Return Loss vs Frequency for Various Supply Voltages Figure 20. Output Return Loss vs. Frequency for Various Supply Currents (IDQ), (VDD), IDQ = 800 mA VDD = 5 V
0 12 –10 +85°C +25°C 10 ) –55°C B –20 (d N B) 8 d IO ( T –30 A L URE O 6 S IG –40 F E SE I IS O +85°C 4 N +25°C –50 EVER –55°C R –60 2 –70 0 18 20 22 24 26 28 30 32 34 36 38 40 42 44
-018
-021
FREQUENCY (GHz)
186 186 20
FREQUENCY (GHz)
20 Figure 18. Reverse Isolation vs. Frequency for Various Temperatures, Figure 21. Noise Figure vs. Frequency for Various Temperatures, VDD = 5 V, VDD = 5 V, IDQ = 800 mA IDQ = 800 mA Rev. 0 | Page 8 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 18 GHz TO 20 GHz FREQUENCY RANGE 20 GHz TO 28 GHz FREQUENCY RANGE 28 GHz TO 36 GHz FREQUENCY RANGE 36 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTIC CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding BIASING THE ADPA7006CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR THE ADPA7006CHIP VGGx AMR (ABSOLUTE MAXIMUM RATING) REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE
