Datasheet ADPA7006CHIP (Analog Devices) - 9
Description18 GHz to 44 GHz, GaAs, pHEMT, MMIC, 1/2 W Power Amplifier
Pages / Page24 / 9 — Data Sheet. ADPA7006CHIP. +85°C. +25°C. –55°C. FREQUENCY (GHz). 700mA. …
File Format / SizePDF / 465 Kb
Data Sheet. ADPA7006CHIP. +85°C. +25°C. –55°C. FREQUENCY (GHz). 700mA. 800mA. 900mA
Data Sheet ADPA7006CHIP +85°C +25°C –55°C FREQUENCY (GHz) 700mA 800mA 900mA
Data Sheet ADPA7006CHIP 36 36 34 34 32 32 30 30 28 28 ) 26 ) 26 m m B 24 B 24 (d (d B 22 B d 22 d P1 20 P1 20 18 +85°C 5V +25°C 18 4V 16 –55°C 16 14 14 12 12 10 10 18 20 22 24 26 28 30 32 34 36 38 40 42 44
-022
-025
FREQUENCY (GHz)
186
FREQUENCY (GHz)
186 20 20 Figure 22. Output Power for 1 dB Compression (P1dB) vs. Frequency for Various Figure 25. P1dB vs. Frequency for Various Supply Voltages (VDD), IDQ = 800 mA Temperatures, VDD = 5 V, IDQ = 800 mA
36 36 34 34 32 32 30 30 28 28 ) 26 ) 26 m m B 24 B 24 (d (d B 22 T d 22 SA P1 20 P 20 18 700mA +85°C 800mA 18 +25°C 16 900mA 16 –55°C 14 14 12 12 10 10 18 20 22 24 26 28 30 32 34 36 38 40 42 44
-023
-026
FREQUENCY (GHz)
186
FREQUENCY (GHz)
186 20 20 Figure 23. P1dB vs. Frequency for Various Supply Currents (IDQ), VDD = 5 V Figure 26. PSAT vs. Frequency for Various Temperatures, VDD = 5 V, IDQ = 800 mA
36 36 34 34 32 32 30 30 28 28 ) 26 ) 26 m m B 24 B 24 (d (d T 22 T 22 SA SA P 20 P 20 18 5V 700mA 4V 18 800mA 16 16 900mA 14 14 12 12 10 10 18 20 22 24 26 28 30 32 34 36 38 40 42 44
-024
-027
FREQUENCY (GHz)
186
FREQUENCY (GHz)
186 20 20 Figure 24. Saturated Output Power (PSAT) vs. Frequency for Various Supply Figure 27. PSAT vs. Frequency for Various Supply Currents (IDQ), VDD = 5 V Voltages (VDD), Drain Current (IDD) = 800 mA Rev. 0 | Page 9 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 18 GHz TO 20 GHz FREQUENCY RANGE 20 GHz TO 28 GHz FREQUENCY RANGE 28 GHz TO 36 GHz FREQUENCY RANGE 36 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTIC CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding BIASING THE ADPA7006CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR THE ADPA7006CHIP VGGx AMR (ABSOLUTE MAXIMUM RATING) REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE
