Datasheet ADTR1107 (Analog Devices)
Description | 6 GHz to 18 GHz, Front-End IC |
Pages / Page | 28 / 1 — 6 GHz to 18 GHz, Front-End IC. Data Sheet. ADTR1107. FEATURES. FUNCTIONAL … |
Revision | A |
File Format / Size | PDF / 943 Kb |
6 GHz to 18 GHz, Front-End IC. Data Sheet. ADTR1107. FEATURES. FUNCTIONAL BLOCK DIAGRAM. VDD_LNA VGG_LNA. VSS_SW CTRL_SW VDD_SW
6 GHz to 18 GHz, Front-End IC Data Sheet ADTR1107 FEATURES FUNCTIONAL BLOCK DIAGRAM VDD_LNA VGG_LNA VSS_SW CTRL_SW VDD_SW Operates from 6 GHz to 18 GHz 25 dBm typical transmit state PSAT 22 dB typical transmit state small signal gain RX_OUT 18 dB typical receive state small signal gain 2.5 dB typical receive state noise figure ADTR1107 ANT Coupled power amplifier output for power detection TX_IN APPLICATIONS
001
Phased array antenna
46-
VGG_PA VDD_PA CPLR_OUT Military radar
221 Figure 1.
Weather radar Communication links Electronic warfare GENERAL DESCRIPTION
The ADTR1107 is a compact, 6 GHz to 18 GHz, front-end IC transmit state, and 18 dB small signal gain and 2.5 dB noise with an integrated power amplifier, low noise amplifier (LNA), figure in receive state. The device has a directional coupler for and a reflective single-pole double-throw (SPDT) switch. These power detection. The input/outputs (I/Os) are internally matched integrated features make the device ideal for phased array antenna to 50 Ω. The ADTR1107 is supplied in a 5 mm × 5 mm, and radar applications. The front-end IC offers 25 dBm of 24-terminal, land grid array (LGA) package. saturated output power (PSAT) and 22 dB small signal gain in
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 ©2020 Analog Devices, Inc. All rights reserved. Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS TRANSMIT STATE RECEIVE STATE THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING TYPICAL APPLICATION CIRCUIT INTERFACING THE ADTR1107 TO THE ADAR1000 X BAND AND KU BAND BEAMFORMER OUTLINE DIMENSIONS ORDERING GUIDE
