Datasheet ADMV7710 (Analog Devices) - 9
Description71 GHz to 76 GHz, 1 Watt E-Band Power Amplifier With Power Detector
Pages / Page18 / 9 — Data Sheet. ADMV7710. 12dBm. 500mA. 14dBm. 600mA. 16dBm. 700mA. 18dBm. …
File Format / SizePDF / 311 Kb
Data Sheet. ADMV7710. 12dBm. 500mA. 14dBm. 600mA. 16dBm. 700mA. 18dBm. 800mA. 20dBm. 900mA. Bm). 3 (. 71.0. 71.5. 72.0. 72.5. 73.0. 73.5. 74.0. 74.5. 75.0. 75.5. 76.0
Data Sheet ADMV7710 12dBm 500mA 14dBm 600mA 16dBm 700mA 18dBm 800mA 20dBm 900mA Bm) 3 ( 71.0 71.5 72.0 72.5 73.0 73.5 74.0 74.5 75.0 75.5 76.0
Data Sheet ADMV7710 40 40 39 12dBm 39 500mA 14dBm 600mA 38 16dBm 38 700mA 18dBm 800mA 20dBm 900mA 37 37 Bm) Bm) d 36 d 36 3 ( 3 ( P P I 35 I 35 UT UT P 34 P 34 UT UT O O 33 33 32 32 31 31 30 30 71.0 71.5 72.0 72.5 73.0 73.5 74.0 74.5 75.0 75.5 76.0
021
14 15 16 17 18 19 20
024
FREQUENCY (GHz) P
16408-
OUT PER TONE (dBm)
16408- Figure 21. Output IP3 vs. Frequency over POUT per Tone, IDD = 800 mA Figure 24. Output IP3 vs. POUT per Tone over IDD, RF = 71 GHz
40 40 39 500mA 39 500mA 600mA 600mA 38 700mA 38 700mA 800mA 800mA 900mA 900mA 37 37 Bm) Bm) d 36 d 36 3 ( 3 ( P P I 35 I 35 UT UT P 34 P 34 UT UT O O 33 33 32 32 31 31 30 30 14 15 16 17 18 19 20
022
025
POUT PER TONE (dBm) P
16408-
OUT PER TONE (dBm)
16408- Figure 22. Output IP3 vs. POUT per Tone over IDD, RF = 73.5 GHz Figure 25. Output IP3 vs. POUT per Tone over IDD, RF = 76 GHz
40 40 GAIN GAIN Bm) Bm) d P1dB d P1dB ( 35 P ( 35 SAT PSAT AT AT S S ), P ), P m 30 m 30 dB dB ( ( dB dB 1 25 1 25 T P T P U U TP 20 TP 20 ), OU ), OU dB dB ( 15 ( 15 IN IN GA GA 10 10 500 600 700 800 900
023
500 600 700 800 900
026
DRAIN CURRENT (mA)
16408-
DRAIN CURRENT (mA)
16408- Figure 23. Gain, Output P1dB, and PSAT vs. Drain Current (IDD), RF = 71 GHz Figure 26. Gain, Output P1dB, and PSAT vs. Drain Current (IDD), RF = 73.5 GHz Rev. A | Page 9 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION ASSEMBLY DIAGRAM MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING OUTLINE DIMENSIONS ORDERING GUIDE
