Datasheet ADMV7710 (Analog Devices) - 10
Description71 GHz to 76 GHz, 1 Watt E-Band Power Amplifier With Power Detector
Pages / Page18 / 10 — ADMV7710. Data Sheet. 1200. GAIN. Bm) d. P1dB. 1100. SAT. AT S. E (%. ), …
File Format / SizePDF / 311 Kb
ADMV7710. Data Sheet. 1200. GAIN. Bm) d. P1dB. 1100. SAT. AT S. E (%. ), P m. 1000. dB (. m B. dB 1. 900. mA) (. T P. I DD. ), P. 800. POUT. ), OU. PAE I. 700. 600. 500
ADMV7710 Data Sheet 1200 GAIN Bm) d P1dB 1100 SAT AT S E (% ), P m 1000 dB ( m B dB 1 900 mA) ( T P I DD ), P 800 POUT ), OU PAE I 700 600 500
ADMV7710 Data Sheet 40 30 1200 GAIN Bm) d P1dB ( 35 P 25 1100 SAT ) AT S E (% ), P m 30 PA 20 1000 ), dB ( m B dB 1 25 (d 15 900 mA) ( UT T P O I DD U ), P TP 20 10 GAIN 800 dB ( POUT ), OU IN PAE I dB DD GA ( 15 5 700 IN GA 10 0 600 500 600 700 800 900
027
–15 –13 –11 –9 –7 –5 –3 –1 1 3 5 7 9 11
030
DRAIN CURRENT (mA)
16408-
INPUT POWER (dBm)
16408- Figure 27. Gain, Output P1dB, and PSAT vs. Drain Current (IDD), RF = 76 GHz Figure 30. Gain, POUT, PAE, and IDD vs. Input Power, RF = 76 GHz, IDD = 700 mA
30 1200 30 1200 25 1100 ) 25 1100 ) E (% E (% PA 20 1000 PA 20 1000 ), ), m B m B (d 15 900 mA) ( (d 15 900 mA) UT ( O UT I DD O I DD ), P ), P 10 GAIN 800 dB GAIN ( P 10 800 OUT dB ( POUT IN PAE PAE I IN GA DD IDD 5 700 GA 5 700 0 600 –15 –13 –11 –9 –7 –5 –3 –1 1 3 5 7 9 11
028
031
INPUT POWER (dBm)
16408-
INPUT POWER (dBm)
16408- Figure 28. Gain, POUT, PAE, and IDD vs. Input Power, RF = 71 GHz, IDD = 700 mA Figure 31. Gain, POUT, PAE, and IDD vs. Input Power, RF = 71 GHz, IDD = 800 mA
30 1200 30 1200 25 1100 ) 25 1100 ) E (% E (% PA 20 1000 ), PA 20 1000 ), m B m B (d 15 900 mA) ( (d mA) UT 15 900 ( O UT I DD O I DD ), P ), P 10 GAIN 800 dB GAIN ( POUT 10 800 dB P IN PAE ( OUT I IN PAE GA DD I 5 700 DD GA 5 700 0 600 –15 –13 –11 –9 –7 –5 –3 –1 1 3 5 7 9 11
029
032
INPUT POWER (dBm)
16408-
INPUT POWER (dBm)
16408- Figure 29. Gain, POUT, PAE, and IDD vs. Input Power, RF = 73.5 GHz, IDD = 700 mA Figure 32. Gain, POUT, PAE, and IDD vs. Input Power, RF = 73.5 GHz, IDD = 800 mA Rev. A | Page 10 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION ASSEMBLY DIAGRAM MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING OUTLINE DIMENSIONS ORDERING GUIDE
