Datasheet HMC8205BF10 (Analog Devices) - 3
Description0.3 GHz to 6 GHz, 35 W, GaN Power Amplifier
Pages / Page14 / 3 — Data Sheet. HMC8205BF10. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table …
RevisionC
File Format / SizePDF / 262 Kb
Data Sheet. HMC8205BF10. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. Parameter. Symbol Min Typ. Max Unit
Data Sheet HMC8205BF10 SPECIFICATIONS ELECTRICAL SPECIFICATIONS Table 1 Parameter Symbol Min Typ Max Unit
TA = 25°C, VDD = 50 V, IDQ = 1300 mA, frequency range = 0.3 GHz to 3 GHz.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 0.3 3 GHz GAIN Small Signal Gain 23 26 dB Gain Flatness ±2 dB RETURN LOSS Input 13 dB Output 12 dB POWER 4 dB Compressed Power P4dB 39 45 dBm Saturated Output Power PSAT 46 dBm Power Gain for PSAT 20 dB Power Added Efficiency PAE 38 % TOTAL SUPPLY CURRENT IDQ 1300 mA SUPPLY VOLTAGE VDD 28 50 55 V TA = 25°C, VDD = 50 V, IDQ = 1300 mA, frequency range = 3 GHz to 6 GHz.
Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 3 6 GHz GAIN Small Signal Gain 25 28 dB Gain Flatness ±2 dB RETURN LOSS Input 10 dB Output 7 dB POWER 4 dB Compressed Power P4dB 39 45 dBm Saturated Output Power PSAT 46 dBm Power Gain for PSAT 19 dB Power Added Efficiency PAE 35 % TOTAL SUPPLY CURRENT IDQ 1300 mA SUPPLY VOLTAGE VDD 28 50 55 V Rev. C | Page 3 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Application Circuit Evaluation PCB Outline Dimensions Ordering Guide
