Datasheet HMC994APM5E (Analog Devices) - 10
DescriptionGaAs pHEMT MMIC POWER AMPLIFIER, DC - 28 GHz
Pages / Page14 / 10 — HMC994APM5E. GaAs pHEMT MMIC. POWER AMPLIFIER, DC - 28 GHz. Absolute …
HMC994APM5E. GaAs pHEMT MMIC. POWER AMPLIFIER, DC - 28 GHz. Absolute Maximum Ratings. Reliability Information
HMC994APM5E GaAs pHEMT MMIC POWER AMPLIFIER, DC - 28 GHz Absolute Maximum Ratings Reliability Information
HMC994APM5E
v04.0218
Drain Bias Voltage (Vdd) +12 Vdc Channel Temperature to maintain 175 °C 1 million Hour mTTf Gate Bias Voltage (Vgg1) -3 to 0 Vdc Thermal resistance T Gate Bias Voltage (Vgg2) 2.5V min up to (Vdd - 5.5V) 25.7 °C/w (channel to ground paddle) m rf input power (rfin) +25 dBm s Continuous pdiss (T= 85 °C) 3.5 w (derate 38.9 mw/°C above 85 °C) r - output load Vswr 7:1 e storage Temperature -65 to 150°C eleCTrosTATiC sensiTiVe DeViCe w oBserVe HAnDlinG preCAUTions operating Temperature -40 to 85 °C o esD sensitivity (HBm) Class 0B, passed 150V.
Stresses at or above those listed under Absolute Maxi-
p
mum Ratings may cause permanent damage to the prod- uct. This is a stress rating only, functional operation of the product at these or any other conditions above those indi- cated in the operational section of this specification is not
r &
implied. Operation beyond the maximum operating condi-
A
tions for extended per 32-Lead Lead Frame Chip Scale Package, Premolded Cavity [LFCSP_CA io V] ds may affect product reliability. 5 x 5 mm Body and 1.25 mm Package Height
e
(CG-32-2) Dimensions shown in millimeters Outline Drawing
lin
DETAIL A (JEDEC 95) 5.10 0.30 5.00 SQ 0.25
s -
PIN 1 4.90 0.20 INDICATOR PIN 1 INDICATOR AREA OPTIONS
r
25 32 (SEE DETAIL A) 24 1
ie
0.50 BSC 3.20 EXPOSED 3.10 SQ PAD
lif
3.00
p
17 8
m
16 9 0.45 TOP VIEW BOTTOM VIEW 0.40
A
3.50 REF 0.35 1.35 0.60 REF SIDE VIEW 1.25 0.40 1.15 0.050 MAX 0.035 NOM COPLANARITY SEATING 0.08 PLANE 0.203 REF PKG-005068 08-30-2016-A
32-lead lead frame Chip scale package, premolded Cavity [lfCsp_CAV] 5 mm × 5 mm and 1.25 mm package Height (CG-32-2)
Package Information
part number package Body material lead finish msl rating [1] package marking HmC994Apm5e roHs-compliant low stress pre-molded plastic nipdAu msl3 HmC994A [1] max peak reflow temperature of 260 °C For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
10
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Power Compression @ 10 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Reverse Isolation vs Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
