Datasheet HMC1099PM5E (Analog Devices) - 3
Description10 W (40 dBm), 0.01 GHz to 1.1 GHz, GaN Power Amplifier
Pages / Page18 / 3 — Data Sheet. HMC1099PM5E. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table …
File Format / SizePDF / 326 Kb
Data Sheet. HMC1099PM5E. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. Parameter
Data Sheet HMC1099PM5E SPECIFICATIONS ELECTRICAL SPECIFICATIONS Table 1 Parameter
TA = 25°C, VDD = 28 V, quiescent current (IDDQ) = 100 mA, and frequency range = 0.01 GHz to 0.4 GHz unless otherwise noted.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 0.01 0.4 GHz GAIN Small Signal Gain 18 20 dB Gain Flatness 2 dB RETURN LOSS Input 12 dB Output 15 dB POWER Output Power POUT 40 dBm Input power (PIN) = 25 dBm 41 dBm PIN = 27 dBm Power Added Efficiency PAE 55 % PIN = 25 dBm 60 % PIN = 27 dBm OUTPUT THIRD-ORDER INTERCEPT OIP3 50 dBm POUT per tone = 30 dBm NOISE FIGURE 8 dB SUPPLY VOLTAGE VDD 24 28 30 V QUIESCENT CURRENT IDDQ 100 mA Adjust the gate bias control voltage (VGG) from −5 V to 0 V to achieve IDDQ = 100 mA, VGG = −2.9 V typical to achieve IDDQ = 100 mA TA = 25°C, VDD = 28 V, IDDQ = 100 mA, and frequency range = 0.4 GHz to 0.8 GHz unless otherwise noted.
Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 0.4 0.8 GHz GAIN Small Signal Gain 16.5 18 dB Gain Flatness 0.5 dB RETURN LOSS Input 8 dB Output 13 dB POWER Output Power POUT 39 dBm PIN = 25 dBm 41 dBm PIN = 27 dBm Power Added Efficiency PAE 45 % PIN = 25 dBm 50 % PIN = 27 dBm OUTPUT THIRD-ORDER INTERCEPT OIP3 47.5 dBm POUT per tone = 30 dBm NOISE FIGURE 5 dB SUPPLY VOLTAGE VDD 24 28 30 V QUIESCENT CURRENT IDDQ 100 mA Adjust VGG from −5 V to 0 V to achieve IDDQ = 100 mA, VGG = −2.9 V typical to achieve IDDQ = 100 mA Rev. B | Page 3 of 18 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Specifications Total Quiescent Current by VDD Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Evaluation PCB Outline Dimensions Ordering Guide
