Datasheet HMC7357LP5GE (Analog Devices) - 5
DescriptionGaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 5.5 - 8.5 GHz
Pages / Page10 / 5 — HMC7357LP5GE. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 5.5 - 8.5 GHz. …
File Format / SizePDF / 728 Kb
HMC7357LP5GE. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 5.5 - 8.5 GHz. Power Compression @ 8 GHz
HMC7357LP5GE GaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 5.5 - 8.5 GHz Power Compression @ 8 GHz
HMC7357LP5GE
v01.0918
GaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 5.5 - 8.5 GHz Power Compression @ 8 GHz Reverse Isolation vs. Temperature
40 1350 -30 T 35 ) % -40 M 30 1300 ) , PAE( 25 B -50 B) d I ( (d dd N N 20 1250 ( AI m IO A -60 T ) ), G A 15 L R - S O Bm -70 10 1200 IS t(d E u Po 5 -80 W 0 1150 O -10 -8 -6 -4 -2 0 2 4 6 8 10 -90 INPUT POWER (dBm) 5.5 6 6.5 7 7.5 8 8.5 Pout Gain PAE FREQUENCY (GHz) Idd +25 C +85 C -40 C R & P A
Gain & Power vs. Gain & Power vs.
E
Supply Current @ 7 GHz Supply Voltage @ 7 GHz
IN 40 40 ) m m 35 (dB 35 (dB at s at s S - L ), P ), P 30 m 30 m R (dB (dB IE 1dB 25 1dB 25 ), P ), P (dB (dB 20 n 20 n LIF ai ai G G P 15 15 M 800 1000 1200 6 7 8 Idd (mA) Vdd (V) A GAIN(dB) P1dB(dBm) Psat(dBm) GAIN(dB) P1dB(dBm) Psat(dBm)
Power Dissipation
10 ) 9 (W N 8 IO PAT 7 ISSI D 6 ER W PO 5 4 -10 -8 -6 -4 -2 0 2 4 6 8 10 INPUT POWER (dBm) 6 GHz 7 GHz 8 GHz For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
5
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features General Description Functional Diagram Electrical Specifications Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature P1dB vs Supply Voltage Output IP3 vs. Supply Voltage, Pout/tone = +20 dBm Output IM3 @ Vdd = +6V Output IM3 @ Vdd =+7V Output IM3 @ Vdd = +8V Power Compression @ 6 GHz Power Compression @ 7 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Package Information Application Circuit List of Materials for Evaluation PCB EV1HMC7357LP5 [1] Evaluation PCB Pin Descriptions Gain & Power vs. Supply Current @ 7 GHz Gain & Power vs. Supply Voltage @ 7 GHz Power Compression @ 8 GHz Reverse Isolation vs. Temperature Output IP3 vs. Temperature, Pout/tone = +20 dBm Output IP3 vs. Supply Current, Pout/tone = +20 dBm P1dB vs. Supply Current Psat vs. Supply Current Psat vs. Temperature Psat vs. Supply Voltage
