Datasheet HMC1087F10 (Analog Devices) - 5
Description8 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 20 GHz
Pages / Page12 / 5 — HMC1087F10. 8 WATT Flange Mount GaN MMIC. POWER AMPLIFIER, 2 - 20 GHz. …
File Format / SizePDF / 733 Kb
HMC1087F10. 8 WATT Flange Mount GaN MMIC. POWER AMPLIFIER, 2 - 20 GHz. Output IM3 @ Vdd= +32V. Power Compression @ 3 GHz
HMC1087F10 8 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 20 GHz Output IM3 @ Vdd= +32V Power Compression @ 3 GHz
HMC1087F10
v04.1217
70 40 900 T 35 875 ) 60 m (% E 30 850 A s 50 ) ), P 25 825 Idd (dB (dBc 40 IN 20 800 (mA) 3 A IM r - ), G 15 775 30 m e 10 750 20 out(dB w P 5 725 o 10 0 700 15 18 21 24 27 30 33 p 3 6 9 12 15 18 21 24 27 30 33 Pout/TONE (dBm) INPUT POWER (dBm) 4 GHz 16 GHz Pout Gain PAE 6 GHz 18 GHz 12 GHz r & Idd A e
Power Compression @ 10 GHz Power Compression @ 19 GHz
40 1300 40 1200 lin 35 1225 ) 35 1125 ) (% (% E 30 1150 E 1050 A 30 A s - ), P 25 1075 ), P 25 975 Idd Idd r (dB (dB IN 20 1000 (mA) IN 20 900 (mA) A A ie ), G 15 925 ), G 15 825 m m 10 850 10 750 lif out(dB out(dB P 5 775 P 5 675 p 0 700 0 600 m 3 6 9 12 15 18 21 24 27 30 33 2 5 8 11 14 17 20 23 26 29 32 A INPUT POWER (dBm) INPUT POWER (dBm) Pout Gain PAE Pout Gain PAE Idd Idd
Gain & Power vs. Gain & Power vs. Supply Voltage @ 10 GHz Supply Current @ 18 GHz
45 45 ) m 40 m 40 35 35 sat (dB sat (dB 30 ), P 30 ), P m m 25 25 (dB (dB 20 20 3dB 3dB 15 ), P 15 ), P 10 10 ain (dB ain (dB G 5 G 5 0 0 24 26 28 30 32 425 450 475 500 525 550 575 600 625 650 675 700 725 750 775 800 825 850 Vdd (V) Idd (mA) GAIN P3dB Psat GAIN P3dB Psat For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
5
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Power Compression @ 10 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
