Datasheet HMC1087F10 (Analog Devices)
Description8 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 20 GHz
Pages / Page12 / 1 — HMC1087F10. 8 WATT Flange Mount GaN MMIC. POWER AMPLIFIER, 2 - 20 GHz. …
File Format / SizePDF / 733 Kb
HMC1087F10. 8 WATT Flange Mount GaN MMIC. POWER AMPLIFIER, 2 - 20 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC1087F10 Analog Devices
HMC1087F10
v04.1217
8 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 20 GHz Typical Applications Features
The HmC1087f10 is ideal for High psat: +38.5 dBm T • Test instrumentation power Gain at psat: 6.5 dB m • General Communications High output ip3: +43.5 dBm s • radar small signal Gain: 11 dB r - • ew/eCm supply Voltage: Vdd = +28V @ 850 mA e 50 ohm matched input/output
Functional Diagram
w 10-lead flange mount package o p
General Description
The HmC1087f10 is an 8w Gal ium nitride (Gan) mmiC power Amplifier which operates between 2 and r & 20 GHz, and is provided in a 10-lead flange mount A package. The amplifier typical y provides 11 dB of e small signal gain, +39 dBm of saturated output power, and +43 dBm output ip3 at +28 dBm output power per lin tone. The amplifier draws 850 mA quiescent current from a +28V DC supply. The rf i/os are matched to s - 50 ohms for ease of use. r ie lif p m A
Electrical Specifications, T = +25° C, Vdd =+28V, Idd = 850 mA [1] A
parameter min. Typ. max. min. Typ. max. min. Typ. max. Units frequency range 2 - 12 12 - 17 17 - 20 GHz Gain 8 11 7.5 10.5 7 10 dB Gain flatness ±0.6 ±0.6 ±0.7 dB Gain Variation over Temperature 0.014 0.024 0.018 dB/ °C input return loss 12 12 12 dB output return loss 13 12 11 dB output power for 3 dB Compression (p3dB) 38.5 37.5 37 dBm power Gain for 3dB compression (p3dB) 8.5 7 6 dB saturated output power (psat) 39.5 38.5 37.5 dBm output Third order intercept (ip3)
[2]
43.5 42.5 42 dBm power Added efficiency 30 17 15 Total supply Current 850 850 850 mA [1] Adjust Vgg between -8 to 0V to achieve idd = 850 mA typical. [2] measurement taken at pout / tone = +28 dBm. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Power Compression @ 10 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
