Datasheet HMC1087F10 (Analog Devices) - 3
Description8 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 20 GHz
Pages / Page12 / 3 — HMC1087F10. 8 WATT Flange Mount GaN MMIC. POWER AMPLIFIER, 2 - 20 GHz. …
File Format / SizePDF / 733 Kb
HMC1087F10. 8 WATT Flange Mount GaN MMIC. POWER AMPLIFIER, 2 - 20 GHz. P3dB vs. Temperature. P3dB vs Supply Voltage
HMC1087F10 8 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 20 GHz P3dB vs Temperature P3dB vs Supply Voltage
HMC1087F10
v04.1217
8 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 20 GHz P3dB vs. Temperature P3dB vs Supply Voltage
45 45 T m 40 40 s (dBm) 35 (dBm) 35 r - P3dB P3dB e 30 30 w o 25 25 2 5 8 11 14 17 20 2 5 8 11 14 17 20 p FREQUENCY (GHz) FREQUENCY (GHz) +25 C +85 C -40 C 24V 28V 32V r & A e
Psat vs. Temperature Psat vs. Supply Voltage
45 45 lin 40 40 s - r (dBm) 35 (dBm) 35 ie Psat Psat 30 30 lif p 25 25 m 2 5 8 11 14 17 20 2 5 8 11 14 17 20 FREQUENCY (GHz) FREQUENCY (GHz) A +25 C +85 C -40 C 24V 28V 32V
P3dB vs Supply Current Psat vs Supply Current
45 45 40 40 (dBm) (dBm) 35 35 P3dB Psat 30 30 25 25 2 5 8 11 14 17 20 2 5 8 11 14 17 20 FREQUENCY (GHz) FREQUENCY (GHz) 425 mA 850 mA 425 mA 850 mA For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
3
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Power Compression @ 10 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
