Datasheet HMC1086F10 (Analog Devices) - 7
Description25 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 6 GHz
Pages / Page12 / 7 — HMC1086F10. 25 WATT FlAnge MounT gAn MMIC. PoWeR AMPlIFIeR, 2 - 6 gHz. …
File Format / SizePDF / 728 Kb
HMC1086F10. 25 WATT FlAnge MounT gAn MMIC. PoWeR AMPlIFIeR, 2 - 6 gHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC1086F10 25 WATT FlAnge MounT gAn MMIC PoWeR AMPlIFIeR, 2 - 6 gHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC1086F10
v06.1017
25 WATT FlAnge MounT gAn MMIC PoWeR AMPlIFIeR, 2 - 6 gHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) +32 Vdc Vdd (V) idd (mA) T Gate Bias Voltage (Vgg) -8 to 0 Vdc +24 1100 m rf input power (rfin) +33 dBm +28 1100 s Channel Temperature 225 °C +32 1100 Adjust Vgg to achieve idd = 1100 mA maximum pdiss (T = 85 °C) r - 60.5w (derate 432 mw/°C above 85 °C) e Thermal resistance
Amplifier Turn-on Procedure:
w 2.31 °C/w (channel to flange bottom) 1.) set Vgg to -5V. o maximum forward 11 mA 2.) set Vdd to +28V. p Gate Current (mA) 3.) ramp gate voltage until quiescent drain current = maximum Vswr
[1]
6:1 1100 mA. storage Temperature -65 to 150 °C
[2]
4.) Apply rf input power. r & A operating Temperature -40 to 85 °C e [1] restricted by maximum power dissipation. [2] This device is not surface mountable and is not intended nor suitable to be
Amplifier Turn-off Procedure:
lin used in a solder reflow process. This device must not be exposed to ambient temperatures above +150°C. 1.) remove rf input power. 2.) set Vgg to -5V. s - 3.) set Vdd to 0V. r 4.) set Vgg to 0V. ie lif p m A eleCTrosTATiC sensiTiVe DeViCe oBserVe HAnDlinG preCAUTions For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
7
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Power Compression @ 10 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
