Datasheet HMC1086F10 (Analog Devices) - 6
Description25 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 6 GHz
Pages / Page12 / 6 — HMC1086F10. 25 WATT FlAnge MounT gAn MMIC. PoWeR AMPlIFIeR, 2 - 6 gHz. …
File Format / SizePDF / 728 Kb
HMC1086F10. 25 WATT FlAnge MounT gAn MMIC. PoWeR AMPlIFIeR, 2 - 6 gHz. Reverse Isolation vs. Temperature
HMC1086F10 25 WATT FlAnge MounT gAn MMIC PoWeR AMPlIFIeR, 2 - 6 gHz Reverse Isolation vs Temperature
HMC1086F10
v06.1017
25 WATT FlAnge MounT gAn MMIC PoWeR AMPlIFIeR, 2 - 6 gHz Reverse Isolation vs. Temperature Second Harmonics vs. Temperature
0 90 -10 80 -20 70 T ) (dBc) -30 C 60 (dB m N -40 50 IO s T -50 LA HARMONI 40 O IS -60 30 r - -70 20 SECOND e -80 10 -90 0 w 2 3 4 5 6 2 3 4 5 6 FREQUENCY (GHz) o FREQUENCY(GHz) p +25 C +85 C -40 C +25 C +85 C -40 C r & A
Second Harmonics vs. Supply Voltage Second Harmonics vs. Pin
e 90 90 80 80 70 70 lin (dBc) (dBc) C 60 C 60 50 50 s - HARMONI 40 HARMONI 40 r 30 30 ie 20 SECOND 20 SECOND 10 10 lif 0 0 2 3 4 5 6 2 3 4 5 6 p FREQUENCY(GHz) FREQUENCY(GHz) m 24V 28V 32V +9 dBm +27 dBm +15 dBm +33 dBm A +21 dBm
Additive Phase noise Vs offset Frequency, RF Frequency = 4 gHz, Power Dissipation RF Input Power = 27 dBm (P1dB)
60 -80 55 -90 (W) 50 ) -100 z /H 45 -110 Bc 40 (d -120 DISSIPATION 35 ISE -130 O N 30 -140 POWER 25 ASE -150 PH 20 -160 6 9 12 15 18 21 24 27 30 33 -170 INPUT POWER (dBm) -180 2 GHz 4 GHz 6 GHz 100 1K 10K 100K 1M 3 GHz 5 GHz OFFSET FREQUENCY (Hz) For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
6
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Power Compression @ 10 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
