Datasheet HMC-APH460 (Analog Devices) - 4
DescriptionGaAs HEMT MMIC 0.5 WATT POWER AMPLIFIER, 27 - 31.5 GHz
Pages / Page6 / 4 — HMC-APH460. GaAs HEMT MMIC 0.5 WATT POWER. AMPLIFIER, 27 - 31.5 GHz. Pad …
File Format / SizePDF / 313 Kb
HMC-APH460. GaAs HEMT MMIC 0.5 WATT POWER. AMPLIFIER, 27 - 31.5 GHz. Pad Descriptions. 3 - 175
HMC-APH460 GaAs HEMT MMIC 0.5 WATT POWER AMPLIFIER, 27 - 31.5 GHz Pad Descriptions 3 - 175
HMC-APH460
v02.0208
Pad Number Function Description Interface Schematic This pad is AC coupled and matched to 1 RFIN 50 Ohms. This pad is AC coupled and matched to 3 2 RFOUT 50 Ohms. IP Power Supply Voltage for the amplifi er. See assembly for 3 Vdd1 H required external components. S - C R Power Supply Voltage for the amplifi er. See assembly for 5 Vdd2 required external components. IE IF L Gate control for amplifi er. Please follow “MMIC Amplifi er Bias- P 4, 6 Vgg1, Vgg2 ing Procedure” application note. See assembly for required M external components. Die bottom must be connected to RF/DC ground. R A Die Bottom GND E W O R & P A E IN L Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
3 - 175
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
