Datasheet HMC591LP5, 591LP5E (Analog Devices) - 6
DescriptionGaAs PHEMT MMIC 2 WATT POWER AMPLIFIER, 6.0 - 9.5 GHz
Pages / Page8 / 6 — HMC591LP5 / 591LP5E. GaAs PHEMT MMIC 2 WATT. POWER AMPLIFIER, 6.0 - 9.5 …
File Format / SizePDF / 412 Kb
HMC591LP5 / 591LP5E. GaAs PHEMT MMIC 2 WATT. POWER AMPLIFIER, 6.0 - 9.5 GHz. Pad Descriptions. 11 - 307
HMC591LP5 / 591LP5E GaAs PHEMT MMIC 2 WATT POWER AMPLIFIER, 6.0 - 9.5 GHz Pad Descriptions 11 - 307
HMC591LP5 / 591LP5E
v02.0107
Pad Number Function Description Interface Schematic 1, 2, 6 - 8, 10 - 12, 14, 15, N/C Not connected. 17 - 19, 23, 24, 26, 27, 29 - 31 Package bottom has an exposed metal paddle 3, 5, 20, 22 GND that must be connected to RF/DC ground. 11 This pad is AC coupled and 4 RFIN matched to 50 Ohms. T Gate control for amplifi er. Adjust to achieve Idd of 1340 mA. Please follow “MMIC Amplifi er Biasing Procedure” 9 Vgg Application Note. External bypass capacitors of 100 pF and 2.2 μF are required. - SM S Power Supply Voltage for the amplifi er. External bypass R 13, 16, 25, 28, 32 Vdd 1-5 capacitors of 100 pF and 2.2 μF are required. IE IF This pad is AC coupled and L 21 RFOUT matched to 50 Ohms. P M R A E W O & P R A E IN L Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Pho - n 25 e: 7 0- 81 3 3 3 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
11 - 307
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
