HMC591LP5 / 591LP5E v02.0107 GaAs PHEMT MMIC 2 WATTPOWER AMPLIFIER, 6.0 - 9.5 GHzEvaluation PCB 11 T - SM S R IE IF L P M R A E W O & P R List of Materials for Evaluation PCB 108190 [1] A The circuit board used in the fi nal application Item Description E should use RF circuit design techniques. Signal J1 - J2 PCB Mount SMA Connector IN lines should have 50 ohm impedance while the J3 - J4 DC Pin L package ground leads and package bottom should C1 - C6 100pF Capacitor, 0402 Pkg. be connected directly to the ground plane similar to C7 - C12 2.2 μF Capacitor, 1206 Pkg that shown. A sufficient number of via holes should U1 HMC591LP5 / HMC591LP5E be used to connect the top and bottom ground PCB [2] 109001 Evaluation PCB planes. The evaluation board should be mounted [1] Reference this number when ordering complete evaluation PCB to an appropriate heat sink. The evaluation circuit [2] Circuit Board Material: Rogers 4350 board shown is available from Hittite upon request. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Pho - n 25 e: 7 0- 81 3 3 3 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com 11 - 309 Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
