Datasheet HMC487LP5E (Analog Devices) - 3
DescriptionSURFACE MOUNT PHEMT 2 WATT POWER AMPLIFIER, 9 - 12 GHz
Pages / Page6 / 3 — HMC487LP5E. SURFACE MOUNT PHEMT 2 WATT POWER. AMPLIFIER, 9 - 12 GHz. …
File Format / SizePDF / 957 Kb
HMC487LP5E. SURFACE MOUNT PHEMT 2 WATT POWER. AMPLIFIER, 9 - 12 GHz. Output IP3 vs. Temperature. Power Compression @ 10.5 GHz
HMC487LP5E SURFACE MOUNT PHEMT 2 WATT POWER AMPLIFIER, 9 - 12 GHz Output IP3 vs Temperature Power Compression @ 10.5 GHz
HMC487LP5E
v03.0819
SURFACE MOUNT PHEMT 2 WATT POWER AMPLIFIER, 9 - 12 GHz Output IP3 vs. Temperature Power Compression @ 10.5 GHz
42 36 T 38 ) % 30 ( M E 34 A ), P 24 ) 30 B m d ( (dB 26 IN 18 A R - S 3 IP ), G E 22 +25 C Pout m 12 +85 C B Gain d 18 -40 C PAE t ( W u o 6 P O 14 10 0 8 9 10 11 12 13 -10 -6 -2 2 6 10 14 18 FREQUENCY (GHz) INPUT POWER (dBm) R & P A
Gain Power and OIP3 Gain, Power and OIP3
E
vs. Supply Voltage @10.5 GHz vs. Supply Current @ 10.5 GHz
IN ) 40 ) 42 m m B 38 B d d ( 3 ( 36 3 38 ), IP 34 ), IP S - L m B m 34 d 32 B d R t ( a 30 t ( s a s 30 IE 28 ), P Gain m ), P B 26 P1dB m Gain d Psat B ( d 26 P1dB B 24 IP3 ( Psat LIF d B 1 IP3 d 22 1 P ), P 22 B 20 ), P d B M ( d in 18 ( a in 18 A G 6.5 7 7.5 a G 800 900 1000 1100 1200 1300 Vdd Supply Voltage (Vdc) Idd Supply Current (mA)
Noise Figure vs. Temperature Reverse Isolation vs. Temperature
15 0 -10 12 ) B d ) -20 ( B E d 9 R ( U N -30 +25 C IG IO T +85 C F A -40 C E L -40 6 IS O O IS N -50 +25 C 3 +85 C -40 C -60 0 -70 8 9 10 11 12 13 8 9 10 11 12 13 FREQUENCY (GHz) FREQUENCY (GHz) For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
3
Application Support: Phone: 1-800-ANALOG-D
