Datasheet HMC453ST89, 453ST89E (Analog Devices) - 2
DescriptionInGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 2 — HMC453ST89 / 453ST89E. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC453ST89 / 453ST89E. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Broadband Gain & Return Loss @ 400
HMC453ST89 / 453ST89E InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Broadband Gain & Return Loss @ 400
v02.0710
InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Broadband Gain & Return Loss @ 400 Gain vs. Temperature @ 400 MHz
25 23 20 22 15 21 20 10 S21 S11 19 5 S22 (dB) 18 0 17 -5 +25 C GAIN 16 +85 C RESPONSE (dB) -10 15 -40 C 9 -15 14 -20 13 -25 12 T 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.35 0.37 0.39 0.41 0.43 0.45 FREQUENCY (GHz) FREQUENCY (GHz)
Input Return Loss Output Return Loss
R - SM
vs. Temperature @ 400 MHz vs. Temperature @ 400 MHz
E 0 0 W -5 -5 O -10 +25 C -10 +85 C -40 C -15 R & P -15 -20 A RETURN LOSS (dB) RETURN LOSS (dB) +25 C E -20 -25 +85 C -40 C IN -25 -30 0.35 0.37 0.39 0.41 0.43 0.45 0.35 0.37 0.39 0.41 0.43 0.45 FREQUENCY (GHz) FREQUENCY (GHz) S - L R IE
P1dB vs. Temperature @ 400 MHz Psat vs. Temperature @ 400 MHz
IF 34 34 L 33 33 P 32 32 M 31 31 A 30 30 29 29 +25 C +25 C 28 +85 C Psat (dBm) 28 +85 C P1dB (dBm) 27 -40 C 27 -40 C 26 26 25 25 24 24 0.35 0.37 0.39 0.41 0.43 0.45 0.35 0.37 0.39 0.41 0.43 0.45 FREQUENCY (GHz) FREQUENCY (GHz) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
9 - 169
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
