Datasheet HMC453ST89, 453ST89E (Analog Devices) - 3
DescriptionInGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 3 — HMC453ST89 / 453ST89E. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC453ST89 / 453ST89E. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Noise Figure. Output IP3 vs. Temperature @ 400 MHz
HMC453ST89 / 453ST89E InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs Temperature @ 400 MHz
v02.0710
InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs. Temperature @ 400 MHz vs. Temperature @ 400 MHz
52 11 50 10 48 9 46 8 44 7 42 6 +25 C GURE (dB) +25 C 40 +85 C 5 9 +85 C OIP3 (dBm) -40 C SE FI 38 4 -40 C 36 NOI 3 34 2 32 1 T 30 0 0.35 0.37 0.39 0.41 0.43 0.45 0.35 0.37 0.39 0.41 0.43 0.45 FREQUENCY (GHz) FREQUENCY (GHz) R - SM
Reverse Isolation Gain, Power & IP3
E
vs. Temperature @ 400 MHz vs. Supply Voltage @ 400 MHz
W 55 0 O 50 -5 45 Gain -10 40 P1dB +25 C Psat OIP3 +85 C 35 R & P -15 -40 C Psat (dBm), OIP3 (dBm) 30 A E ISOLATION (dB) -20 25 20 IN -25 15 -30 10 0.35 0.37 0.39 0.41 0.43 0.45 4.5 4.75 5 5.25 5.5 GAIN (dB), P1dB (dBm), S - L FREQUENCY (GHz) Vs (Vdc) R IE
ACPR vs. Supply Voltage @ 400 MHz
IF
Power Compression @ 400 MHz W-CDMA, 64 DPCH
L 45 -10 P -15 40 Pout M Gain -20 35 PAE W-CDMA A -25 Frequency: 400 MHz 30 -30 Integration BW: 3.84 MHz 64 DPCH -35 25 -40 4.5V 20 5V -45 5.5V ACPR (dBc) 15 -50 -55 10 Pout (dBm), Gain (dB), PAE (%) -60 5 -65 Source ACPR 0 -70 0 2 4 6 8 10 12 14 16 8 10 12 14 16 18 20 22 24 26 28 INPUT POWER (dBm) Channel Power (dBm) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
9 - 170
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
