Datasheet HMC453QS16G, 453QS16GE (Analog Devices) - 7
DescriptionInGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 7 — HMC453QS16G / 453QS16GE. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC453QS16G / 453QS16GE. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Output IP3 vs. Temperature @ 900 MHz
HMC453QS16G / 453QS16GE InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Output IP3 vs Temperature @ 900 MHz
v01.0205
InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Output IP3 vs. Temperature @ 900 MHz Noise Figure vs. Temperature @ 900 MHz
54 10 52 9 50 8 48 7 46 6 44 GURE (dB) 5 11 +25 C +25 C 42 OIP3 (dBm) +85 C 4 +85 C SE FI 40 -40 C 3 -40 C NOI 38 2 T 36 1 34 0 0.75 0.8 0.85 0.9 0.95 1 0.7 0.75 0.8 0.85 0.9 0.95 1 1.05 1.1 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Reverse Isolation Gain, Power & IP3 vs. Temperature @ 900 MHz vs. Supply Voltage @ 900 MHz
0 55 50 -5 PLIFIER 45 -10 40 M +25 C +85 C 35 -15 -40 C Psat (dBm), OIP3 (dBm) 30 ISOLATION (dB) -20 25 Gain ER A P1dB Psat 20 OIP3 W -25 15 O -30 10 0.7 0.75 0.8 0.85 0.9 0.95 1 1.05 1.1 4.5 4.75 5 5.25 5.5 GAIN (dB), P1dB (dBm), FREQUENCY (GHz) Vs (Vdc) & P R
Gain, Power & IP3 ACPR vs. Supply Voltage @ 910 MHz
A
vs. Supply Current @ 900 MHz*
E
CDMA IS95, 9 Channels Forward
55 -25 LIN 50 -30 45 -35 CDMA IS95 Frequency: 910 MHz 40 -40 Integration BW: 1.228 MHz Forward Link, 9 Channels 35 -45 Psat (dBm), OIP3 (dBm) 4.5V 30 -50 ACPR (dBc) 5.5V 25 Gain 5V P1dB -55 Psat 20 OIP3 -60 15 -65 10 Source ACPR -70 480 520 560 600 640 680 720 760 800 GAIN (dB), P1dB (dBm), 12 14 16 18 20 22 24 26 28 30 Icq (mA) Channel Power (dBm) * Icq is controlled by varying VPD. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 184
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
