Datasheet HMC453QS16G, 453QS16GE (Analog Devices) - 9
DescriptionInGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 9 — HMC453QS16G / 453QS16GE. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC453QS16G / 453QS16GE. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Noise Figure
HMC453QS16G / 453QS16GE InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure
v01.0205
InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs. Temperature @ 1900 MHz vs. Temperature @ 1900 MHz
52 10 50 9 48 8 46 7 44 6 42 GURE (dB) 5 11 40 +25 C +25 C OIP3 (dBm) 4 +85 C 38 SE FI +85 C 3 -40 C 36 -40 C NOI 34 2 T 32 1 30 0 1.7 1.8 1.9 2 2.1 1.7 1.8 1.9 2 2.1 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Reverse Isolation Gain, Power & IP3 vs. Temperature @ 1900 MHz vs. Supply Voltage @ 1900 MHz
0 55 50 45 PLIFIER -5 40 M 35 +25 C -10 +85 C Psat (dBm), OIP3 (dBm) 30 -40 C 25 ISOLATION (dB) Gain ER A 20 P1dB -15 Psat 15 OIP3 W 10 O -20 5 1.7 1.8 1.9 2 2.1 4.5 4.75 5 5.25 5.5 GAIN (dB), P1dB (dBm), FREQUENCY (GHz) Vs (Vdc) & P R
Gain, Power & IP3 ACPR vs. Supply Voltage @ 1960 MHz
A
vs. Supply Current @ 1900 MHz* CDMA 2000, 9 Channels Forward
E 55 -30 50 LIN -35 45 CDMA2000 -40 Frequency: 1.96 GHz 40 Integration BW: 1.228 MHz -45 35 Forward Link, SR1, 9 Channels 4.5V 5V Psat (dBm), OIP3 (dBm) 30 -50 5.5V 25 ACPR (dBc) Gain -55 20 P1dB Psat -60 OIP3 15 -65 10 Source ACPR 5 -70 480 520 560 600 640 680 720 760 800 14 16 18 20 22 24 26 28 GAIN (dB), P1dB (dBm), Icq (mA) Channel Power (dBm) * Icq is controlled by varying VPD. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 186
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
