Datasheet HMC461LP3, 461LP3E (Analog Devices) - 2
DescriptionInGaP HBT 1 Watt High IP3 AMPLIFIER, 1.7 - 2.2 GHz
Pages / Page8 / 2 — HMC461LP3 / 461LP3E. InGaP HBT 1 Watt High IP3. AMPLIFIER, 1.7 - 2.2 GHz. …
File Format / SizePDF / 479 Kb
HMC461LP3 / 461LP3E. InGaP HBT 1 Watt High IP3. AMPLIFIER, 1.7 - 2.2 GHz. Broadband Gain & Return Loss
HMC461LP3 / 461LP3E InGaP HBT 1 Watt High IP3 AMPLIFIER, 1.7 - 2.2 GHz Broadband Gain & Return Loss
HMC461LP3 / 461LP3E
v02.0705
InGaP HBT 1 Watt High IP3 AMPLIFIER, 1.7 - 2.2 GHz Broadband Gain & Return Loss Gain vs. Temperature
15 20 +25C 17 +85C 5 -40C 14 S21 (dB) -5 S11 S22 GAIN 11 -15 11 GAIN & RETURN LOSS (dB) 8 -25 5 T 1 1.5 2 2.5 3 1.7 1.8 1.9 2 2.1 2.2 2.3 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Input Return Loss vs. Temperature Output Return Loss vs. Temperature
R 0 0 IE -5 -5 IF +25C L -10 +85C +25C -40C P -10 +85C -40C -15 M -15 -20 RETURN LOSS (dB) RETURN LOSS (dB) R A -20 -25 E -25 -30 W 1.5 1.7 1.9 2.1 2.3 2.5 1.5 1.7 1.9 2.1 2.3 2.5 O FREQUENCY (GHz) FREQUENCY (GHz) & P R
P1dB vs. Temperature Psat vs. Temperature
A 33 33 E 31 31 IN L 29 29 +25C 27 Psat (dBm) 27 +85C P1dB (dBm) -40C +25C 25 +85C 25 -40C 23 23 1.7 1.8 1.9 2 2.1 2.2 2.3 1.7 1.8 1.9 2 2.1 2.2 2.3 FREQUENCY (GHz) FREQUENCY (GHz) Specifi cations and data refl ect HMC461LP3 measured with external baluns in a balanced amplifi er confi guration optimized for 1.85 - 2.2 GHz per application circuit herein. Contact HMC Applications for 1.7 - 1.85 GHz performance optimization. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Pho - n 25 e: 7 0- 81 3 3 3 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
11 - 251
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
