Datasheet HMC461LP3, 461LP3E (Analog Devices) - 3
DescriptionInGaP HBT 1 Watt High IP3 AMPLIFIER, 1.7 - 2.2 GHz
Pages / Page8 / 3 — HMC461LP3 / 461LP3E. InGaP HBT 1 Watt High IP3. AMPLIFIER, 1.7 - 2.2 GHz. …
File Format / SizePDF / 479 Kb
HMC461LP3 / 461LP3E. InGaP HBT 1 Watt High IP3. AMPLIFIER, 1.7 - 2.2 GHz. Output IP3 vs. Temperature
HMC461LP3 / 461LP3E InGaP HBT 1 Watt High IP3 AMPLIFIER, 1.7 - 2.2 GHz Output IP3 vs Temperature
HMC461LP3 / 461LP3E
v02.0705
InGaP HBT 1 Watt High IP3 AMPLIFIER, 1.7 - 2.2 GHz Output IP3 vs. Temperature Noise Figure vs. Temperature
50 10 47 8 44 6 GURE (dB) 11 +25C IP3 (dBm) 41 4 +85C SE FI -40C NOI +25C 38 2 +85C -40C T 35 0 1.7 1.8 1.9 2 2.1 2.2 2.3 1.7 1.8 1.9 2 2.1 2.2 2.3 FREQUENCY (GHz) FREQUENCY (GHz) - SM S R
Power Compression @ 1.95 GHz Power Compression @ 2.15 GHz
IE 54 54 IF 48 48 L 42 42 Pout Pout P Gain Gain 36 PAE 36 PAE M 30 30 24 24 R A 18 18 E 12 12 Pout (dBm), GAIN (dB), PAE (%) Pout (dBm), GAIN (dB), PAE (%) W 6 6 0 0 O -10 -4 2 8 14 20 26 -10 -4 2 8 14 20 26 INPUT POWER (dBm) INPUT POWER (dBm) & P R
Gain & Power vs.
A
Reverse Isolation vs. Temperature Supply Voltage @ 2.15 GHz
E 0 ) 32 m B IN 30 t (d L -5 28 a s 26 +25C -10 ), P +85C 24 m -40C B 22 G ain (d -15 B 20 P 1dB d 1 18 P s at ISOLATION (dB) -20 ), P 16 B 14 (d -25 in 12 a G 10 -30 8 1.5 1.6 1.7 1.8 1.9 2 2.1 2.2 2.3 4. 5 4.75 5 5. 25 5.5 FREQUENCY (GHz) S UP P LY V OL T AG E (V dc) Specifi cations and data refl ect HMC461LP3 measured with external baluns in a balanced amplifi er confi guration optimized for 1.85 - 2.2 GHz per application circuit herein. Contact HMC Applications for 1.7 - 1.85 GHz performance optimization. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 252
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
