Datasheet HMC414MS8G, 414MS8GE (Analog Devices) - 6
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 2.2 - 2.8 GHz
Pages / Page8 / 6 — HMC414MS8G / 414MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 2.2 - 2.8 …
File Format / SizePDF / 383 Kb
HMC414MS8G / 414MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 2.2 - 2.8 GHz. Pin Descriptions. 11 - 63
HMC414MS8G / 414MS8GE GaAs InGaP HBT MMIC POWER AMPLIFIER, 2.2 - 2.8 GHz Pin Descriptions 11 - 63
v04.0607
Pin Number Function Description Interface Schematic This pin is AC coupled 1 RFIN and matched to 50 Ohms. 2 NC Not Connected. 3, 4 RFOUT RF output and DC bias for the output stage. 11 T Ground: Backside of package has exposed metal ground slug that must be 5 GND connected to ground thru a short path. Vias under the device are required. - SM Power control pin. For maximum power, this pin should be connected to S 6, 8 Vpd1, Vpd2 3.6V. For 5V operation, a dropping resistor is required. A higher voltage is R not recommended. For lower idle current, this voltage can be reduced. IE IF L P Power supply voltage for the fi rst amplifi er stage. An external bypass 7 Vcc capacitor of 330 pF is required as shown in the application schematic. M R A E W O & P R A E IN L Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Pho - n 25 e: 7 0- 81 33 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 www.analog.com
11 - 63
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
