Datasheet HMC981 (Analog Devices) - 6
DescriptionACTIVE BIAS CONTROLLER
Pages / Page18 / 6 — HMC981. ACTIVE BIAS CONTROLLER. Absolute Maximum Ratings [1]. Outline …
File Format / SizePDF / 886 Kb
HMC981. ACTIVE BIAS CONTROLLER. Absolute Maximum Ratings [1]. Outline Drawing
HMC981 ACTIVE BIAS CONTROLLER Absolute Maximum Ratings [1] Outline Drawing
HMC981
v00.0611
VDD 12V Thermal Resistance (R ) TH 52.1 °C/W (Junction to package bottom) VG2_CONT, VDRAIN -0.5V to VDD + 0.5V Storage Temperature -65 to +150 °C SW, EN, CP_OUT, VGATEFB, IP VNEGFB, TRIG_OUT, DISBL_SC, -0.5V to VDIG + 0.5V Operating Temperature -55 to +85 °C H ISENSE ESD Sensitivity (HBM) Class 1B VDIG 5.5V Note that there are two different voltage domains on HMC981; a VNEG -4V to GND high voltage domain Vdd, and a low voltage domain VDIG. Take necessary precautions not to violate ABS MAX ratings of each S - C VG2 -0.5V to VDD + 0.5V subdomains. R Junction Temperature 125 °C Continuous Pdiss (T = 85 °C) 0.77 Watts (Derate 19.19 mW/°C above 85 °C) LLE NOTES: 1. ALL DIMENSIONS IN INCHES [MILLIMETERS] O 2. DIE THICKNESS IS 0.010 (0.254) R 3. TYPICAL BOND PAD IS 0.0039 SQUARE 4. BOND PAD METALLIZATION: ALUMINUM T ELECTROSTATIC SENSITIVE DEVICE 5. NO BACKSIDE METAL N OBSERVE HANDLING PRECAUTIONS 6. NO CONNECTION REQUIRED FOR UNLABELED BOND PADS 7. OVERALL DIE SIZE IS ±.002 O
Outline Drawing
S C IA B Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
