Datasheet ADRF5515 (Analog Devices) - 9
DescriptionDual-Channel, 3.3 GHz to 4.0 GHz, 20 W Receiver Front End
Pages / Page15 / 9 — Data Sheet. ADRF5515. +105°C. +25°C. –40°C. Bm). ( 3. B ( 1d. T IP. UT P. …
File Format / SizePDF / 413 Kb
Data Sheet. ADRF5515. +105°C. +25°C. –40°C. Bm). ( 3. B ( 1d. T IP. UT P. UT O. 3.3. 3.4. 3.5. 3.6. 3.7. 3.8. 3.9. 4.0. 4.1. 4.2. OUTPUT POWER (dBm)
Data Sheet ADRF5515 +105°C +25°C –40°C Bm) ( 3 B ( 1d T IP UT P UT O 3.3 3.4 3.5 3.6 3.7 3.8 3.9 4.0 4.1 4.2 OUTPUT POWER (dBm)
Data Sheet ADRF5515 40 30 +105°C +105°C +25°C +25°C –40°C –40°C 35 25 ) Bm) dB d ( 3 B ( 1d T IP 30 20 U P TP UT P OU UT O 25 15 20 10 0 2 4 6 8
014
015
OUTPUT POWER (dBm) FREQUENCY (GHz)
23029- 23029- Figure 14. Output IP3 vs. Output Power at Various Temperatures, 3.6 GHz Figure 15. Output P1dB vs. Frequency at Various Temperatures Rev. 0 | Page 9 of 15 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings for ADRF5515 ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS RECEIVE OPERATION, HIGH GAIN MODE RECEIVE OPERATION, LOW GAIN MODE TRANSMIT OPERATION THEORY OF OPERATION SIGNAL PATH SELECT Transmit Operation Receive Operation BIASING SEQUENCE APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
