Datasheet ADRF5545A (Analog Devices) - 3
DescriptionDual-Channel, 2.4 GHz to 4.2 GHz Receiver Front End
Pages / Page20 / 3 — Data Sheet. ADRF5545A. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. …
File Format / SizePDF / 441 Kb
Data Sheet. ADRF5545A. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min Typ. Max. Unit
Data Sheet ADRF5545A SPECIFICATIONS ELECTRICAL SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 5 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
VDD1-CHA, VDD1-CHB, VDD2-CHA, VDD2-CHB, and SWVDD-CHAB = 5 V; SWCTRL-CHAB = 0 V or SWVDD-CHAB; BP-CHA = VDD1-CHA or 0 V; BP-CHB = VDD1-CHB or 0 V; PD-CHAB = 0 V or VDD1-CHA; case temperature (TCASE) = 25°C, 50 Ω system, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 2.4 4.2 GHz GAIN1 Receive operation at 3.6 GHz High Gain Mode 32 dB Low Gain Mode 16 dB GAIN FLATNESS1 Receive operation in any 100 MHz bandwidth High Gain Mode 0.6 dB Low Gain Mode 0.2 dB NOISE FIGURE (NF)1 Receive operation at 3.6 GHz High Gain Mode 1.45 dB Low Gain Mode 1.45 dB OUTPUT THIRD-ORDER INTERCEPT POINT Receive operation, two-tone output power = 8 dBm per tone (OIP3)1 at 1 MHz tone spacing High Gain Mode 32 dBm Low Gain Mode 29 dBm OUTPUT 1 dB COMPRESSION (OP1dB) High Gain Mode 19 dBm Low Gain Mode 12 dBm INSERTION LOSS1 Transmit operation at 3.6 GHz 0.65 dB Channel to Channel Isolation1 At 3.6 GHz Between RXOUT-CHA AND RXOUT-CHB Receive operation 47 dB Between TERM-CHA AND TERM-CHB Transmit operation 52 dB SWITCH ISOLATION ANT-CHA TO TERM-CHA AND ANT-CHB Transmit operation, PD-CHAB = 0 V 25 dB TO TERM-CHB1 SWITCHING CHARACTERISTICS (tON, tOFF) 50% control voltage to 90%, 10% of RXOUT-CHA or 860 ns RXOUT-CHB in receive operation 50% control voltage to 90%, 10% of TERM-CHA or TERM-CHB 800 ns in transmit operation RF INPUT POWER AT ANT-CHA, ANT-CHB1 Receive operation, LTE average (9 dB PAR) 15 dBm INPUT 0.1dB COMPRESSION (P0.1dB) 100 µs pulse width, 10% duty cycle, TCASE = 25°C2 50 dBm RECOMMENDED OPERATING CONDITIONS Bias Voltage Range VDD1-CHA, VDD1-CHB, VDD2-CHA, VDD2-CHB, 4.75 5 5.25 V SWVDD-CHAB Control Voltage Range SWCTRL-CHAB, BP-CHA, BP-CHB, PD-CHAB 0 V 3 DD V RF Input Power at ANT-CHA, ANT-CHB SWCTRL-CHAB = 5 V, PD-CHAB = 5 V, BP-CHA = BP-CHB = 0 V, TCASE = 105°C2 Continuous wave 40 dBm 9 dB PAR LTE full lifetime average 40 dBm 9 dB PAR LTE single event (<10 sec) average 43 dBm Case Temperature Range (TCASE)2 −40 +105 °C Junction Temperature at Maximum T 2 CASE Receive operation1 132 °C Transmit operation1 134 °C Rev. B | Page 3 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS 2.6 GHZ TUNED OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS RECEIVE OPERATION, HIGH GAIN MODE RECEIVE OPERATION, LOW GAIN MODE TRANSMIT OPERATION RECEIVE OPERATION, HIGH GAIN MODE WITH 2.6 GHZ TUNING RECEIVE OPERATION, LOW GAIN MODE WITH 2.6 GHz TUNING TRANSMIT OPERATION AT WITH 2.6 GHz TUNING THEORY OF OPERATION SIGNAL PATH SELECT Transmit Operation Receive Operation BIASING SEQUENCE APPLICATIONS INFORMATION 2.6 GHZ OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
